Front Wheel Bearing balls in Honda Accord 1994 EX F22b1
Old Mar 28, 2010 | 06:56 PM
faran's Avatar
Icon6 Front Wheel Bearing ***** in Honda Accord 1994 EX F22b1
I replaced the Front Brake Rotors on my car today I used sliding hammer to pull the old Rotors out while pulling one of the Rotor 2 ***** from the Driver side wheel bearing came out I just put them back in the bearing with a lot of grease my concern is that will that be an issue with the bearing or should I continue to drive it like that as it wo'nt be an issue.
Any help or suggestions will be greatly appreciated.
Old Mar 28, 2010 | 06:59 PM
djkurious's Avatar
Default Re: Front Wheel Bearing ***** in Honda Accord 1994 EX F22b1
When I did the rotor over hub conversion, the bearing came apart when we were pressing it onto the hub (like 2 pieces). I pressed it back on and haven't had any problems with breakage, road noise, or anything. My 2 cents: you should be fine.
gnx547
Jun 1, 2009 06:47 PM
spyderazn
Mar 9, 2008 05:28 PM
deklao
Feb 20, 2008 07:56 PM
bigislandc2
May 20, 2007 09:45 AM
zack88
Dec 4, 2004 09:03 AM
