crx rear interior panels question
how do you remove? or be able to slide them?
because both my driver and passenger side are not wrapped around the door frame
n i need to get them put back in plaace before they crack
not my car nor pic but example
pics to show us what you are talking about.
i know the interrior panels are have clips to hold them into place. are you just referring to the portion that goes by the door jamb? if so then take a flat head screw driver and pry on it till it holds.
like i said, pull on it. or you can undo the clips that hold it in place. then align the front section, followed by clipping the rear section to its spots.
DONT pull on it and slip it over the door jam! you will end up stretching the piece and causing it to stress and possible crack or rip. just remove them. it takes about literally 10 minutes to remove them. do it right. don't half *** and have the possibility of it cracking.
to remove them, you remove the center cargo covers. open the cargo and you will find screws(not sure how many, forgot). after those screws are removed, you can now remove the center cargo area. remove the rear panels. then you can start to see some hidden screws that hold the side pieces together. after you remove those screws, tug on the panels as they are held in by clips. carefully remove them without too much of a force.
JonnySBeee...
Mar 7, 2005 04:05 PM
Tatakai
Sep 20, 2004 03:23 AM
