da axles in an ef
Old Mar 28, 2010 | 12:54 PM
ej1project's Avatar
Default da axles in an ef
i just picked up an ls and i still need the harness and axles and some other odds and ends but i was wondering if i could use da b series axles in an ef with an ls
Old Mar 28, 2010 | 03:40 PM
dephtone's Avatar
Default Re: da axles in an ef
You HAVE to use DA axles when putting in a B series into an EF. They will fit in the hubs except if you are running STD or HF hubs as these are 20 splines and I believe the DX and SI are 21 splines.
Depending on which intermediate shaft it came with you will get a 90-93 or 94+ axles.
90-93 intermediate shaft has a female end on it and the 94+ has a male end.
As far as the wiring harness goes you should use the one that came with the car as no other harness will plug up to your cars stock underdash harness. This means you cannot use a LS engine harness with any of the EF underdash unless you want to splice and that just gets you in a deep hole quick.
Old Mar 28, 2010 | 04:03 PM
jxh_28's Avatar
all u need is
DA (91 to 93 integra manual) axles. NO AUTO.
female haftshaft (DA, of course) and NO AUTO again.
then ur good to go
Old Mar 28, 2010 | 08:03 PM
ej1project's Avatar
thanks for the help and yeah its an si so i should be good and yeah ill just use the stock harness then,
Ef4doorwagon
Feb 4, 2015 10:31 PM
Toe_fur
10
Jun 9, 2013 03:10 PM
jdmallmotorhatch
Oct 28, 2008 09:57 AM
creepy116
Sep 28, 2007 09:39 AM
r6king28
Aug 8, 2006 11:49 AM
