help with trouble code
Old Mar 28, 2010 | 12:40 PM
LS_VTECteggy's Avatar
Default help with trouble code
Hey, checked my check engine light today and got the code P1362, can you tell me what it is, and solutions on fixing it? Thanks
Old Mar 28, 2010 | 02:09 PM
Default Re: help with trouble code
alright so I found out what it is, but it's mostly on civic, not integra and no definite answer to where this is, can anyone point me in the right direction on how to fix this problem?
Old Mar 28, 2010 | 06:58 PM
no help at all? I did my research and can't fine anything guys, im stuck what do I do?
Old Mar 28, 2010 | 07:05 PM
mouab18c1's Avatar
P1362 Top Dead Center (TDC) Sensor No Signal
Check your distributor
Old Mar 28, 2010 | 07:09 PM
WDG_729_ITR's Avatar
Check out this thread...a guy had a similar problem and ended up replacing the distributor...could be the solution.
http://www.hondacarforum.com/honda-3...ode-p1362.html
Old Mar 28, 2010 | 07:16 PM
ty guys and I did read that WDC but just wanted to get your guys input, I'm turboing my car within the next month and I was hoping this doesn't get in the way
Old Mar 28, 2010 | 07:18 PM
Nice...what's your set-up going to be?
Old Mar 28, 2010 | 07:20 PM
im running t3/t04e turbo, HKS bov, running 7psi with AEM FIC hoping to make around 250 hp but the dyno is gonna know that
Old Mar 28, 2010 | 07:26 PM
-T3/T04 is the flange size...what brand turbo?
-What kind of exhaust manifold?
-What size injectors?
I guess if you're only planning to make 250HP it will be a pretty basic/minimal set-up...
Let me know if you need any help figuring out what you're going to buy to turbo it...I can help you piece together a kit.
Old Mar 28, 2010 | 07:30 PM
well is there anyway you can get your hands on a downpipe going down the passenger side with a bung hole?
Old Mar 28, 2010 | 07:37 PM
Would something like this be sufficient?
http://cgi.ebay.com/ebaymotors/3-5-b...Q5fAccessories
-Note: Ebay is good for minor things such as piping...I recommend getting a good brand name Turbo, Wastegate, BOV, Injectors (DSM 440CC Injectors are good for basic/minimal set-ups)...for everything else, e-bay should be alright (for a basic/minimal set-up).
Old Mar 28, 2010 | 07:41 PM
getting 450cc injectors, and that downpipe is on the wrong side and most of my stuff is from ebay
Old Mar 28, 2010 | 07:47 PM
You want one that exits off the passenger side, right?...doesn't this do that?
http://cgi.ebay.com/ebaymotors/integ...Q5fAccessories
Old Mar 28, 2010 | 07:50 PM
yea that's good thanks
Old Mar 28, 2010 | 07:52 PM
No problem. Post some pictures when you turbo it...i'd like to see the car before/after.
Ucha v-tec
Honda Civic (2001 - 2005)
Aug 4, 2018 11:09 AM
crnimacak
Mar 20, 2006 10:04 PM
willsEK-HF
Mar 3, 2006 09:51 PM
