WTB H22 F23 B18 Parts
I need some parts for my swap:
-H22 valve cover (can have paint chipped off, don't care)
-H22 OBD-1 Dizzy (USDM or JDM)
-H22 VTEC Solenoid
-H22 IACV, OBD-1 Injectors, IAB, Throttle body (or a full intake manifold)
-H22 aftermarket header or JDM header
-H22 stock head bolts
-OBD-1 P13 ECU
-F23 Bearing set (rods, main, thrust, please no used bearings)
-F23 Crank pulley (aftermarket, only alternator pulley)
-Water pump to run H22 timing belt on G23?
-B-series flywheel (OEM)
-90 integra LS clutch set (aftermarket, can be slightly used)
-EF B-series swap mounts (can be ebay)
-EF CRX Igniton switch w/ key
-EF CRX wire harness or OBD-1 prelude wire harness
-OBD-0 to OBD-1 ECU adapter
-Radiator hoses for H22 into EF or universal flexable hoses
-K20A3 Pistons (all 4 with pins)
Let me know if you have these parts. Thanks.
-H22 VTEC Solenoid
-OBD-1 P13 ECU
got a OBD1 P13 ECU
2 sets of HASport EF b-series mounts (old steel ver & new billet ver)
H22 dizzy
H22 header (aftermarket)
BNIB Skunk2 Pro series intake manifold for H22
PM me and I'll get you pic & prices if your interested.
H22 dizzy
97 accord se
Apr 25, 2006 11:45 PM
