6 SHOCK's on a ef ???!!!!
Old Mar 28, 2010 | 07:54 AM
lilsicsoul's Avatar
Icon3 6 SHOCK's on a ef ???!!!!
Yes I did search but can't find nothing on this....
Story::
My boy was selling his 91 dx a few days ago and I wanted to buy the muffler from him so I get under the back bumper to get a better look at we're I should cut....
BOOM 2 extra shock on a angle!!!??
First ef I see with 4 shocks on the back!!!
Lil info on this please....
PS:
He let me have them for free
And ther going on my 89 4door....
Old Mar 28, 2010 | 08:00 AM
black0hatch's Avatar
Default Re: 6 SHOCK's on a ef ???!!!!
post up some pics. ive seen multiple shock on lifted trucks.
Old Mar 28, 2010 | 08:06 AM
Turbo Dan's Avatar
You were under the car, and you want random people on the internet to explain why a car has two extra shocks welded somewhere under the car.
Talk to the person that owns the car.
Post pictures so we can at least laugh at this.
Old Mar 28, 2010 | 08:25 AM
lilsicsoul's Avatar
^^ reading might not be your strong point...lol
They we're not welded..
the lca's had holes on them for the shocks to be bolted...
Car is sold and i took the extra shock's..
I should of taken pics..smH..
I will post pics next sat when I bolt them on my car....
Old Mar 28, 2010 | 08:27 AM
Eaglekper0046's Avatar
The extra hole is most likely for the swar bar
Old Mar 28, 2010 | 08:33 AM
Turbo Dan's Avatar
What's the point of this thread? What are you asking?
You gutted an EF with ghetto suspension and now you're installing it on your own car.
I don't get it
Old Mar 28, 2010 | 08:57 AM
lilsicsoul's Avatar
True... idk
I just wanted some info on this because I never seen it before but insted I have mr d!ck face posting useless ****...
Might be some back yard job .. all just keep searching see what I can find
Old Mar 28, 2010 | 09:13 AM
Turbo Dan's Avatar
"might be a backyard job"
How about, 100% positive it is a backyard job.
Old Mar 28, 2010 | 09:40 AM
who cars if its a back yard job or if its ghetto suspension. the dude wants to know why would some one use extra shocks. and op you wont find good info like that on a honda site. try sites for offroad 4x4's those guys are at the top of their game in suspension design.
Old Mar 28, 2010 | 09:51 AM
Turbo Dan's Avatar
You can add 10 shocks per side if you want, you can add as many shocks as you want to an EF suspension.
You can tape shocks to your doors too.
You can talk to as many 4x4 owners you want, they won't be able to tell you why your civic has useless shocks attacked to the LCA.
It's like finding a winch bolted to the door of the car you just bought.
Retarded on so many levels.
Additionally, EF's are equipped with "stuts" not "shocks"
if you are talking about a "shock" this is clear indication that it doesn't belong on the car.
Old Mar 28, 2010 | 09:54 AM
BiG ChOr!Zo's Avatar
this thread is full of win (not)
skipbudlong's Avatar
Should have taken pictures man. See what happens? You know everyone always flames on h-t, for incomplete info.
Old Mar 28, 2010 | 10:23 AM
Clipsed's Avatar
Actually you are WRONG, the 4th gen civic is equipped with SHOCK's, once you attach the spring, to the shock, the ASSEMBLY is then called a MacPherson STRUT. HOWEVER, TRUE STRUTS are completely different in DESIGN and FUNCTION. STRUTS are also a structural component of the suspension, and can take the place of two or three suspension components of other systems and are usually used as a pivot point for steering and to adjust the position of the wheels for alignment purposes. Educate yourself a little before giving bad info.
Old Mar 28, 2010 | 10:28 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
I know what happened... They took out the strut to "slam" the car and in its place bolted 2 shocks per side. It makes sense, (looking at it from the retard's point of view) after you remove the struts there would be two holes on the wheel well left over. (Three if you count the center for the shock to protrude.) If one were to purchase standard style 2WD front truck shocks, then they would fit perfectly. It would be one shock on one side of the lower control arm and the mirror image on the other side.
Of course, if there is still a strut installed then they probably just used the extra hole for a rear sway bar and drilled a hole in the wheel well. Then they slapped an extra shock on there so they could pull wheelies.
Now lastly, if they actually put 2 strut assemblies per side on the rear, I would love to meet this individual and kick him square in the *********.
Old Mar 28, 2010 | 10:33 AM
Clipsed's Avatar
I get the feeling that it was the stock shock along with a hood/trunk damper...
Old Mar 28, 2010 | 10:35 AM
DO IT ON ALL FOURS
Not being a dick... but you say a "MacPherson STRUT" is a shock with a spring sandwiched between the rod and dead end. You also say that a "TRUE STRUT" is a pivotal point in the suspension for steering purposes. The problem is your attached pictures shows a "MacPherson STRUT" as an articulating suspension piece that moves with the steering assembly. You are contradicting yourself and I shall recommend you correct your description.
Old Mar 28, 2010 | 11:12 AM
Clipsed's Avatar
touche... I didn't notice that, it was the first pic that popped up, and I only looked at the shock, and not the rest of the suspension components... Struts have adjustments unlike our older Macpherson strut style where it plays no role in adjustment...
However the idea is that a Macpherson strut is a more compact design over seperating the shock and spring, and was designed mainly for FWD cars with limited space.
Old Mar 28, 2010 | 12:35 PM
Turbo Dan's Avatar
I always just thought a 'strut' was an surrounded by the spring, where as a shock could be independent of the spring.
Old Mar 28, 2010 | 03:47 PM
B16-CRX's Avatar
Useless thread
Old Mar 28, 2010 | 03:48 PM
lilsicsoul's Avatar
yes its 2 extra shocks * no springs*
on a angle
i did do a lil search and the holes for the sway bar are in a diff place from what
the holes for the extra shocks are.. im trying to get a hold of the new owner
to bolt 1 shock and take pics... and post them here...
Old Mar 28, 2010 | 03:49 PM
lilsicsoul's Avatar
Originally Posted by B16-CRX
Useless thread
what ever you say cool guy...
Old Mar 28, 2010 | 03:50 PM
lilsicsoul's Avatar
pics coming in a few days....
dj_zyx
Jul 2, 2007 10:38 AM
Francois
Suspension & Brakes
Dec 6, 2005 06:16 PM
