Header clearance?
Well I have a ITR swap w/ hasport mounts and I want to get a nice header since I am putting on a JRSC. Now on to my questions,
Does any know the header for the best ground clearance??
I have heard get a tri-y.
Will it fit with a full width rad?
I have enough cash for the traction bar and header....right now.
Any other input is great, I am not wanting to spend more then 500 bucks on a header.
Anyone have experience with this one?
http://www.logicmotorsports.com/Prod...Tri+Y&CartID=1
Headers + EFs = clearance issues.
It's a rather oversimplified truth. But still a truth.
If you are running a JRSC Kamkazi header is pretty much your best choice anyway, it's tuned for a roots/eaton blower. Time and again it seems to out do high end n/a styled headers.
Traction bar wil free up some room but unless you are running a long tube drag style rad fit mint shouldn't be an issue, but these cars have shifted with age and well, don't hold any of this to a truth. Sadly measure and bringing a hammer is often the case.
It's true but with any (95%) header you choose for an EF (B-Series) you will have to notch the crossmember (which is a cheaper route then doing the traction bar setup). I have talked to a guy that tried 3 headers on his B16/EF: Type-R replica, Tri-Y, and RMF replica. He told me that the 4-1 Type-R replica has the most clearance, and I can't remember which of the other 2 are lower but they are LOWER.
The Logic Motorsports IMO looks to be the best designed header that has the most clearance.
If you plan on lowering your car really low any header will get beat up. But, if you just lower it to a finger gap or two you will be okay. I have a 1991 CRX with a B16A which is supercharged (JRSC). Also running a full radiator with a Full Race traction bar setup. And I am lowered 1 finger gap with no issues with my JDM ITR header. Only on huge speed bumps I need to go sideways. But on normal ones going straight is fine. If you ask most of the supercharged honda guys/girls. The Kamkazi header will be the header of choice for a JRSC kit. And you should not spend no more than $250-$300 for a header for your setup.
Forgot to mention there is a great JRSC thread if you need anymore advice. I linked the thread below if you want to check it out. It has lots of great info.
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2A-official-jrsc-thread%2A%2A%2A-1214810/
Thanks I have been in that thread but 500 pages is a bit to much.... LOL
will the 2 1/2'' collector bolt to a stock cat? Do I need a high flow cat and if so what flanges will I need?
It won't bolt up to a stock cat because of the bolt pattern plus it's really small, plus you don't want to restrict your exhaust like that. Look into picking up a high-flow cat from Vibrant or Magnaflow. They range from $70-$120 for a universal; you will want a 2.5" universal cat. If you want it to have flanges then it will cost you more, or just have some flanges welded on (don't know what kind).
I guarantee you it will be loud, you can trust me on that. I'm was running a Magnaflow high-flow cat + canister muffler and it was loud; so I added a Magnaflow resonator which did quiet it down more but it's still not as quiet as the brand name exhausts. Plus, save the environment! I'm serious.
i just put on a comptech header today. clearance was not an issue with the crossmember, except it had to be removed and reinstalled to get the header in since it is a one piece. as for gound clearance my coil sleeves are bottomed out and there doesnt seem to be anyissue.
92TEGsrSC
Jul 29, 2003 05:54 PM
