Turn Signals Stopped Working!!!!
Old Mar 28, 2010 | 04:20 AM
KGB_JDM's Avatar
Default Turn Signals Stopped Working!!!!
IM in the process of building my 97 teg. Im in the final stage of putting everything back together. I was checking all my turn signals, headlights, taillights and hazards to make sure i connected everything correctly. I pushed in my hazards and the lights in the cluster blinked but when i try to use my turns they would blink. I did some research about this already and it seems to be a common problem with this car. Can anyone just telling me how to fix it? I still need to get my car inspected so I need to get this fixed...any advice would help.
thanks thomas
Old Mar 30, 2010 | 06:31 AM
KGB_JDM's Avatar
Default Re: Turn Signals Stopped Working!!!!
Anyone??
Old Mar 30, 2010 | 07:03 AM
LSracing94's Avatar
check that the hazard switch is fully plugged in..it activates ur blinkers too
Old Mar 30, 2010 | 09:54 AM
Blahblah718293's Avatar
on the fuse block under the dash, there should be one fuse off to the right side, like it was an afterthaught, make sure that fuse is good, i dont know what number it is.
and while your down there, check all the other fuses as well.
Old Apr 6, 2010 | 02:29 PM
KGB_JDM's Avatar
Yesterday I change the flash relay for the turns and hazard and checked all the fuse and still nothing....any more advice?
Old Apr 8, 2010 | 07:03 PM
KGB_JDM's Avatar
can someone show me a pic of the fuse that they are talking about that is to the far right?? that control the lights...rechecked my fuse, getting no power up to my combo switch....ANYONE HELP?
Old Apr 9, 2010 | 07:00 AM
Domnificent's Avatar
i have the same issue with my right taillight
Old Apr 9, 2010 | 04:33 PM
boosting4life35's Avatar
check the fuse block under the dash maybe thats the problem
Old Apr 9, 2010 | 05:23 PM
KGB_JDM's Avatar
I bought another fuse block today...switched everything over and nothing! So my teg is going to the Honda dealership so there shop can work on it and find what's wrong! I'll post what they find
Old Apr 9, 2010 | 06:40 PM
the 10 amp fuse all the way on the right is the one i was reffering to.
Old Apr 9, 2010 | 08:15 PM
Coldhydro's Avatar
I had the same problem a few years back. It was a fuse. I forgot which one exactly but it was one under the hood. Might want to check those too if you haven't.
Old Apr 9, 2010 | 08:51 PM
KGB_JDM's Avatar
I'm missing that fuse to the right all together...
EM2_PLo
Honda Civic (2001 - 2005)
Jul 19, 2010 12:54 PM
Masho
Jul 17, 2010 02:24 PM
k20eklipse
26
Jul 12, 2010 08:55 PM
401RIguy
Mar 13, 2009 07:25 AM
91blackEF
Jan 11, 2009 05:55 PM
