EF/DA parts interchangeable?
I'm picking up an '88 hatch and a '91 DA on wednesday and I was wondering what parts are interchangeable on the two cars. Planning on building the hatch and using the DA for parts and the swap. I know suspension parts are interchangeable and so are brakes but what else? The DA has really good seats so I was wondering if those fit. Thanks...
The DA seats will fit but with only 3 bolts holding them in but remember they do sit higher in an EF than your current stock does.
You can use the LS motor if it still has that in it. You will have to buy the supporting items to go with it, such as mounts and linkage.
Ok sweet. It should be fine since I'm only 5' 9". I know I need B series mounts and I can just cut integra shift linkage by 2.25" to make it work right?
Just cut some small pieces out of your linkage, mock it up under the car with the engine and trans in the final position. Spot weld it, take it down, and go to town.
