Accord F22 VTEC Swap Distributor Question Harness Help
Old Mar 27, 2010 | 06:54 PM
sadam-insane's Avatar
Default Accord F22 VTEC Swap Distributor Question Harness Help
Ok guys now this is the second time straight Ive run into the same problem with an OBD2 car swapped with an OBD1 engine. I have an 97 Accord ex with Vtec the bells and whistles etc,,, Now the guy picked up an engine exact same engine except its an obd1 F22 Vtec we did the sensor on the head swap plugged everything up except for the distributor has two plugs and the car has or had the crank postion sensor on the crank....
1. With the OBD1 dizzy... if I jus wire up the CYP and TDC etc properly as per helms and or the chilton.... is this a good way out? is there a "cam difference that wit knock everything out of sinq?
2. Do I need to swap the OBD2 CYP sensor on the OBD1 engine and keep the dizzy OBD2?
I searched...
Old Mar 28, 2010 | 06:12 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Accord F22 VTEC Swap Distributor Question Harness Help
http://ff-squad.com/wp/?p=309
Old Mar 28, 2010 | 07:03 PM
Ok that is the same thing I did on the civic I swapped last year... that doesnt work. The trick on this accord would prob result in the same thing. But is there ANYONE on here who has succesfulley deppined or wired the Cyp out put and get positive results?
Today I pulled the sensors from the crank area on the OBD2 engine with harness? now isther a away to wire up the haress to the jdm dizzy and get this thing going? Or is the ODB2 to OBD1 the better route?
Old Mar 31, 2010 | 10:50 AM
Originally Posted by HondaPartsHero
Will this work on the Accord series?
Also has anyone tried the cam swap ect and does the sensor transfer on the JDM F22
Old Apr 2, 2010 | 03:03 PM
Found exactly what I needed This should be in the FAQs for Accords if posible...
I know this site is Civic and Integra leaner ... but if any one asks maybe this couyld be pulled up now on searches
http://rywire.com/store/automatic-ob...9537364f2a8ad7
http://www.f22parts.com/Item_Harness.htm
http://www.accordinglydone.com/forum...ad.php?t=12424
http://hondaaccordforum.com/forum/sh...ad.php?t=24313
http://www.forumshawaii.net/vbb/show....php?p=6143583
skidmarkroyalty
Nov 20, 2008 07:55 AM
Spaceballsthelunchbox
Feb 23, 2007 07:22 AM
jbonehead85
Dec 8, 2004 04:01 PM
therealnapster
Aug 24, 2001 06:47 PM
