Brake Trouble
Old Mar 27, 2010 | 12:43 PM
cyclonedr's Avatar
Icon2 Brake Trouble
Hello all,
I have been having intermittent brake trouble for the last couple of months. I've finally pinpointed the problem, but am not sure how to go about solving it. What happens is the outside pad on the drivers side is not releasing when I release the brake, so it's not completely braking, but it's not releasing either. The result is an annoying squeal or grinding noise that goes away after I reach speeds above 35 mph - I think the pad is just wearing away, though nothing conclusive. I discovered the stuck pad when I was taking apart the caliper, and had to use a clamp to pull the pad off, it was really stuck. All my other pads pretty much just fell out, so I'm assuming that something is wrong. I've greased the part of the caliper where the tips of the pad touch, but that didn't seem to help, since I had to do a bit of work to get it back in. If you have any ideas, I would appreciate it.
Thanks
Cyclone
Old Mar 27, 2010 | 01:26 PM
jdmwannabee's Avatar
Default Re: Brake Trouble
sounds like your caliper is seizing. you can either rebuild it or replace it.
Old Mar 27, 2010 | 05:21 PM
CRZ1's Avatar
you can try to grease the sliding pin with Permatex® Ceramic Extreme Brake Parts Lubricant or sil-glyde
Old Mar 27, 2010 | 10:03 PM
arkangel2487's Avatar
just to be clear, are ur slides moving ok or u talking about the pad being stuck in the braket. if its number 2 u need to sand down the top an bottom of the pad, get new pads, or get new hardware
ef8cybercrx
Nov 17, 2007 10:40 PM
roundworldsobig
Aug 26, 2006 06:12 PM
MugenHonda
Jan 27, 2005 09:03 AM
OEMcivic
Dec 22, 2004 11:58 PM
mikeds122
Sep 25, 2004 12:55 PM
