Suspension & Brakes Theory, alignment, spring rates....
Struts Shot
Old Mar 27, 2010 | 08:50 AM
djakal47's Avatar
Default Struts Shot
So my struts on my 03 TL are shot and I need to find a place that has decent to good struts for a low cost online.
Old Mar 27, 2010 | 11:37 AM
STOCK_SOHC_DX's Avatar
Default Re: Struts Shot
Maybe these?
http://thmotorsports.com/eibach/eiba...0/i-53964.aspx
Old Mar 27, 2010 | 09:26 PM
djakal47's Avatar
its way cheaper then getting new ones from acura it was around $650 with tax for 4 new struts
Old Mar 28, 2010 | 03:14 PM
98civdx's Avatar
Master Detailer
how about koni strt?
http://www.jegs.com/p/Koni/Koni-STRT...43342/10002/-1
Old Mar 30, 2010 | 07:50 AM
djakal47's Avatar
they didnt have em on that link for 03 TL
Old Mar 30, 2010 | 09:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Need to know your needs/wants. Just need stock replacement? Stock ride height or lowered?
Old Mar 30, 2010 | 11:25 AM
98civdx's Avatar
Master Detailer
^what he said, you could also call them or koni.
Old Mar 31, 2010 | 12:24 PM
shockguys's Avatar
Assuming you haven't lowered your TL, We have Monroe Sensatrac and KYB GR2 struts if you're just looking for a basic replacement, and KYB AGX adjustable struts if you're looking for an upgrade.
Check them out here:
http://www.shockwarehouse.com/index....cted_year=2003
Old Apr 5, 2010 | 10:13 AM
djakal47's Avatar
The car isnt lowerd but the fact that i need new struts im considering lowering 1.5"-2" I just don't know how well it is going to ride but for now im looking for direct replacement because acura wanted to charge $650 with tax
Old Apr 5, 2010 | 10:26 AM
djakal47's Avatar
if i lower my car should i go with coilovers or loweringsprings??
Old Apr 5, 2010 | 10:44 AM
98civdx's Avatar
Master Detailer
for that amount of drop id get a good set of springs maybe tein s tech or ebiach and koni yellow.
Old Apr 5, 2010 | 10:47 AM
djakal47's Avatar
I don't know if I should put that much money into my TL im going to get rid of it in the Summer of 2011 for an Accord Coupe, Lancer Evo X GSR, or maybe a new civic si if they change the bodystyle and add some power to it. But I need new struts no matter what
Old Apr 5, 2010 | 10:50 AM
98civdx's Avatar
Master Detailer
oh ok.... in that case i woudnt even lower it.... just throw some oe replacements in it.
Old Apr 8, 2010 | 11:23 PM
misweetrevenge's Avatar
stupid question i know but im new to suspenssions. my struts are shot. i was gonna get some coilovers. if i get the coilovers will i need to get new struts as well? or does the coilover replace that? im pretty sure it replaces it but i wana double check
Old Apr 10, 2010 | 10:59 AM
djakal47's Avatar
no ull eventually have to replace ur struts after about a year after lowering ur car coilovers and springs go around ur struts, u need strut-tamers to remove springs and coil-overs, its separate and it wont replace it it replaces ur current spring or coil-over what ever u have in ur car
Old Apr 10, 2010 | 11:01 AM
ok thanks
Old Apr 18, 2010 | 10:43 PM
quick question
i orderd some struts offline
the description on the invoice that came in the box does not match the description thats on my reciept
but the part numbers are the same
basically what im askin is
all that matters is the part number right?
Old Apr 22, 2010 | 07:28 PM
djakal47's Avatar
i have no clue the only thing i bought offline was my head unit and parts for my intake so im not sure how that works exactly... sorry
92eg412
Suspension & Brakes
Jun 10, 2009 07:15 AM
John Haggerty
Honda Civic (2006 - 2015)
Jan 28, 2009 03:43 PM
Slowboy!
Nov 22, 2005 03:26 PM
92LudeSI
Jan 15, 2004 08:55 PM
spartu5
13
Apr 17, 2003 09:27 PM
