Old Apr 6, 2015, 10:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Fan Comes On After Vehicle Shut Down
Old Mar 26, 2010 | 07:49 PM
kornerk12's Avatar
Default Fan Comes On After Vehicle Shut Down
1995 Accord LX
I noticed today that after I turned the car off the fan ran for about 10 mins and then shut down and has been doing the same thing each time I drive since. The temp gauge is about 3/7th, basically alittle less than half way up, and stay steady. Why is the fan running after I shut down, it rarely ever did this before ? It also seems to not want to come on at idle but immediately after I turn the car off after idling for awhile the fan will come on and run for 10 mins or so.
Old Mar 27, 2010 | 01:10 AM
CuteAccord's Avatar
Default Re: Fan Comes On After Vehicle Shut Down
It's normal. It's exclusive to some Accords, helps cool the car, that's all. Should only run for about 3 minutes.
Old Mar 27, 2010 | 08:26 AM
kornerk12's Avatar
yes but this seems odd just because it never happened before and why does the fan turn on after the car is off but was not on while the car was running ?
Old Mar 27, 2010 | 08:32 AM
quickster's Avatar
your fan can come on after you turn it off. this is why you always need to make sure to unplug the battery when you are working around that area.
Old Mar 27, 2010 | 09:07 AM
zillacles's Avatar
Has your temp gauge always read 3/5 of the way up?
Normally was at 1/2 way or just below on my Accord / other cars.
Old Mar 27, 2010 | 10:58 AM
The-Kid's Avatar
Are you missing coolant? Supposedly, if you're driving on flat roads or any condition. The needle should be around 2/5, with A/C on or not.
Might want to check your cooling system.
Old Mar 27, 2010 | 01:45 PM
hypervish's Avatar
I don'tthink this is normal. I recently bought another accord and the fan would turn on once i turned the car off. About a week or two later i replaced the thermostat and now the fan doesn't turn on when the car is off.
Old Mar 27, 2010 | 04:23 PM
fleetw00d's Avatar
It is normal. When you shut the engine off, it stops circulating coolant. The heat in the block will continue to heat the coolant in the engine. If the temperateure gets high enough, the fan will come on until the coolant temperature drops.
Old Mar 27, 2010 | 04:41 PM
quickster's Avatar
flush your coolant out with new stuff if its been over 30k miles since the last time. make sure to bleed ALL air from the system by loosening the bleeder screw and letting coolant come out until its a stead flow. tighten the bleeder screw. take off the cap of the radiator. turn your car on and turn the heater on full blast. let it run until the fan comes on twice. while you are waiting, squeeze all the larger coolant hoses. you will probably see some additional air bubbles come out. if that doesnt fix your problem, try replacing the thermostat, could be getting gummed up and not opening the valve properly. its a cheap and VERY worth it fix. cars get detroyed from overheating FAST, so dont mess around.
Old Mar 27, 2010 | 05:31 PM
kornerk12's Avatar
I actually just replaced my thermostat and all the coolant in the radiator. Its a Stant thermostat 180 degree. The same exact one that was in there previously. I loosened the bleeder screw and there was a steady flow. The only problem was I could not get the fan to cycle. I let the car run for about 0.5 hour at idle with the cap off burping the system, and squeezing the upper hose many times. I have driven the car about 20 miles so far, and check the level, its good and overflow is good also.
As far as something relating to the battery causing this, how could this be ?
Old Mar 27, 2010 | 06:30 PM
bseriescrxsi's Avatar
the are 2 fan switched one controls the fans when car running the other when car off...they are located on the engine side of the upper and lower rad hoses....for the life of me i cant remember which ones on n which ones off but im sure someone will chime in with it
Old Mar 27, 2010 | 06:37 PM
KRIS05VVTi's Avatar
its normal broskii my cb7 does that all the time
Old Mar 27, 2010 | 08:19 PM
kornerk12's Avatar
I always thought one was while the car was running/off and the other was while the AC was running.... ? I am not 100 % sure about this.
Old Mar 27, 2010 | 09:16 PM
arkangel2487's Avatar
u actually have a switch for ur gauge and another to turn the fans on and off. buutt u also have an oil temp sensor which will turn the fan on. either way the computer will turn the fan on if temps reach 225(its around there) on either sensor. even with the car off. as for it being okay, its not. u should check ur sensor resistance or cooling system performance. and my cd5 only gets to half way on the gauge. 3/4 is high
Old Mar 28, 2010 | 07:08 AM
kornerk12's Avatar
Sorry guys I dont know why i didnt realize this before i said 3/5ths i meant to say 3/7th because its alittle below half way up and does not seem to move at all. At idle it will not cycle the fans with the gauge reading this low but the fans will come on after the engine is shut down.
Old Mar 28, 2010 | 07:26 AM
ej1serge's Avatar
It's normal my gf asked me the same question but it is normal
Old Mar 28, 2010 | 09:06 AM
redbull-1's Avatar
It's normal. You can read about it here: http://techauto.awardspace.com/overheating.html
Old Mar 28, 2010 | 07:34 PM
quickster's Avatar
When you bleed your coolent system for air, you do the bleeder screw which i see you already did, but you also need to take your radiator cap off and runs the car with the heater on full blast usually to get your fan to turn on, after it turns on twice pop the cap back on and try to see if that fixes the problem, the coolant system is really picky. I usually just pop a small sized hole in my thermostat to get the air out.
Old Mar 29, 2010 | 01:57 AM
plugger's Avatar
The fans coming on is normal, but the reason it's doing it more noticeably is because you are running hotter. That's almost certainly because you haven't bled your cooling system for air properly. It's a very common reason for engines to run hotter than they should.
Bleed the coolant of air properly and your fan activity will go back to how they were previously.
Old Mar 29, 2010 | 04:52 AM
like i said before its not ok and if ur going to post a link about it read it first so u dont look like a u know what
Proper operation: A number of Honda/Acura with an advance cooling system employ a fan timer system to offset the fragile aluminum head. The timer allows the condenser fan to know when and how long the fan should operate. By switching the ignition off and the coolant temperature exceeds the boiling point the radiator fan will kick in. (However, both the condenser fan and the cooling fan will run when the A/C is on at any temperature.) The fan timer should run for almost exactly 15 minutes and 18 seconds if the engine temp is over 223F. If it is running less than or greater than 15 minutes, or the fan going on/off randomly while the ignition is on or off then either the fan timer is bad, the fan relay, or perhaps there's a bad connection somewhere. If the fan timer system fail to turn on the fan, serious damage to the head and head gasket could occur some time in the future.
Problem: The fan runs continuously (longer than 19-minutes) when the key is removed. The symptom is a dead battery. The fan turns off only when the ignition is turn off then on. 99% chance the fan timer is bad. Usually happens to the 90-93 Accords.
and most of u that are saying it is ok have cb7's
Solution: The reasonable solution is to replace the timer control unit. Before replacing the unit it would be prudent to troubleshoot. When the fan does not turn off after 15 minutes swap the cooling fan relays in the engine fuse compartment with another identical relay. If the fan refuses to turn off replace the fan timer unit.
Replacement: Remove the access panel on the driver's kick panel and search for a box way in there the size of two cigarette packs with 8-terminals. The 86-89 Accord fan timer unit is located under the passenger seat. Unbolt the unit and swap it with a new one.
Old Mar 29, 2010 | 09:26 AM
kornerk12's Avatar
I bleed it correctly, steady steam and the coolant temp (according to the gauge), is fine. Like I mentioned before I meant to say 3/7th, slightly more than 1/4 of the way up. I have no drivability issues at all, and the coolant level is good. The only thing I could not do is have the fans cycle, I had the car running for over 30mins and nothing. Car was at operating temp, again according to the gauge, for atleast 20 of those mins and it would not cycle the fan. However I was getting a steady steam out of the bleeder. The thermostat in the car is the same brand and model number as before, a stant 180 degree thermostat.
Old Mar 29, 2010 | 09:29 AM
kornerk12's Avatar
Here is a pic I took today. Drove the car for about 25 mins, around 10 miles. Mixture of city and highway.
Old Mar 29, 2010 | 10:02 AM
quickster's Avatar
Did you bleed the system with your heater blowing full blast?
Old Mar 29, 2010 | 10:24 AM
as i said dude the fans are controlled by switches.....and it IS normal for them to run after the car is off i have a 90 and a 96.....but if ur fan switch is bad for the car running the car may be running slightly hot but not hot enough to notice and requires extra cool down...replace the fan switch(s) and you should be fine...i say both because yes the one isnt turning the fans on when the car is on but the other may be keeping them on to long when the cars off
Old Mar 29, 2010 | 09:23 PM
Targa250R's Avatar
be professional
That's one of your problems right there.
The Stant single-stage thermostats you can buy in most chain parts stores do not work properly in Honda cars. Period. If I had a dollar for every cooling system problem I've seen caused by one of those, I wouldn't have to work.
Go to a Honda dealership and buy an OEM two-stage thermostat. Honda OE thermostat suppliers are Nippon Thermostat and Fuji Thompson. They work properly.
