FS:JDM B18C LONG BLOCK
Selling real 00 JDM B18C (Gsr) long block (MINUS THE TURBO AND EXHAUST MANIFOLD). Approx 60km (APPROX 25K MILES). COMPLETELY STOCK. Here are some of the specs on the JDM motor. THIS MOTOR IS BASICALLY SIMILAR TO OUR AMERICAN SPEC TYPR-R SOME COMPRESSION AND PISTONS
Will include intake manifold and engine harness JUST WANT TO BE VERY CLEAR MOTOR IS FLAWLESS MOUNT IT IN YOUR CAR AND TURN KEY AND YOUR DRIVING!!!!! NEVER GOT A CHANCE TO BOOST IT AS YOU CAN SEE TURBO IS BRAND NEW NEVER USED BECAUSE I MOUNED IT BUT I HAVEN'T PUT ENGINE BACK IN THE CAR TO US IT.
Prefer local sale only. CALL to discuss if not local. $1700.00 954-213-2421.
PICS posted 3/27/10 @ 12noon!
WILL CONSIDER TRADES IF YOUR ON BOOST LOOKING TO GO ALL MOTOR. YOUR TURBO SET UP CAN'T HAVE ANY ISSUES
- High-volume intake manifold, hand-polished intake ports
- Twin-coil intake valve springs with oval cross-section for high lift
- Lightweight, high flow intake valves to extend engine rev range by 200 rpm
- High-lift, high-strength connecting rods
- High-rigidity, 8-counterweight crankshaft to reduce vibration at high rpm
- High-compression (10.6:1), low-friction pistons
- High-volume air box with repositioned intake
- Aluminum oil cooler maintains optimum engine-oil temperature
- High-flow exhaust system - 30% improvement
