Bad Ecu???
Old Mar 26, 2010 | 02:49 PM
1988EFHB's Avatar
Default Bad Ecu???
So my ECU was throwing a 17, 4, and 3 fixed the 17 changed map sensor for the 3 and then rest it now its throwing a 3, 6, 7, and 10 could i just have a bad ECU?
Old Mar 26, 2010 | 02:50 PM
BiG ChOr!Zo's Avatar
Default Re: Bad Ecu???
try using another known working ecu from a friend before throwing money on a new one...!!!
Old Mar 26, 2010 | 05:35 PM
Je2RiT's Avatar
Could be a bad ECU.
But, just trouble shoot all the codes before you consider buying a new one.
What have you done before all the codes were popping up?
Old Mar 26, 2010 | 06:50 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Did you just do an engine swap or something?
Usually multiple codes are a loose ground wire or the
sensors plugged in with the wrong connectors..
91crx93civic
Mar 22, 2010 06:34 AM
kim_2_da_chee
May 30, 2003 06:18 PM
