wiring diagram
I could get you a wiring diagram from work, but not till monday cause we're not open on weekends :/ Do what you can for now, those lights are a very simple parallel circuit design. Do voltage drops at the grounds and the bulb.
i dont work again till monday, but i can scan the fsm on my lunch break if you'd like.
PLEEEEEEEEEEEASE could one of you post the fsm. thank you!!!!!!!!! <3 there is no power going to my parking lights but the brake lights and blinkers work. also my cluster light is out. no its not the fuse. thanks everybody!
same thing happened to me about4 days ago...make sure that two wires by the fusebox isnt touching and blowing the fuse.....just so happened that the guage lights and the tail light wires were touching each other and by the time i found out, the guage wires was completely melted away and the tail light was burnt!! check it out u never know...
