Image needed: Rear disc e-brake cable connection to caliper
Hello, I'll be picking up a set of rear disc tomorrow for my EK and the disc ebrake cables are included but not attached. The seller says I need a screw or something to get it working.
Does anyone have a close up pic of how the e-brake cable attaches to the rear disc caliper? I want to make sure the cable is the correct one.
I looked on Majestic Honda for the parts diagram and it wasn't very detailed.
Thanks!
This site was really cool but I didn't see a pic that would help me identify how the cable connects to the rear caliper.
http://www.jmetz.net/hatch_rear_discs/
Thanks!
i believe its just a pin... Jw, what are you paying for the setup? i have a disk brake complete swap i need to sell. not sure what its worth..
Just checked on my car, it is a pin and then a clip to hold the pin in (or a carter pin). My cell phone is dead or i will take a pic of the pin your needing.
if you look at the diagram below,
(referenced from 99-00 civic Si)
you'll need:
#16 oem honda part no. 4371-sd2-930 pin, brake wire end (X2) $1.81 ea
#20 oem honda part no. 90705-sd2-931 pin, snap (6MM) $1.61
the pin/ anchor attaches to the e-brake lever
#23 & #33 in the diagram below
http://www.hondapartsdeals.com
you'll need:
Sweet! I saw that pic but it was smaller on the Majestic Honda page and I couldn't make out the end of the cable.
So now I know I should have a cable like this when I pick up the brakes tomorrow.
Thanks for the info.
vtec4eternity
Aug 24, 2009 07:58 PM
tekstyle
Dec 10, 2007 01:40 AM
sirsmokesalot
Jul 16, 2006 11:18 AM
CXHatchback
10
Oct 13, 2002 08:23 PM
