HELP!!! Vibration Under Acceleration
Old Mar 26, 2010 | 11:53 AM
EeF's Avatar
EeF
Default HELP!!! Vibration Under Acceleration
I have a 90 Civic Si w/ a B16 w/ hydro tranny. Under normal accelaration I have vibration in 2nd and 3rd gear. I changed the transmission thinking it was that. I also replaced the axles w/ hasport hydro axles and also replaced the lower ball joints and all the bushing in the lower control arms w/ energy suspension bushing. Check all suspension componenets, nuts bolts etc... Balance the tires twice and also had the car aligned. But I'm still having the same problem. What else could it possibly be? Wheel bearing, tie rods, differential bearing, transmission differential itself?
Old Mar 26, 2010 | 11:56 AM
.Manny.'s Avatar
Touching My Member
Default Re: HELP!!! Vibration Under Acceleration
Checked the radius rods too??
Old Mar 26, 2010 | 11:57 AM
Tyson's Avatar
check your rear subframe. near the rear motor mount. probably cracked.
Old Mar 26, 2010 | 03:09 PM
EeF's Avatar
EeF
Will check it out this weekend. Thanks
Will check this out also. Thanks
Old Mar 26, 2010 | 03:17 PM
.Manny.'s Avatar
Touching My Member
Hope you find it man, that must be really frustrating.
Old Mar 26, 2010 | 03:22 PM
EeF's Avatar
EeF
Yeah man really sucks. i hope i solve the problem. Anyone else with suggestions please let me know. Thanks
Old Mar 26, 2010 | 03:23 PM
AaronJ's Avatar
as far as i know this could be wheel bearings too.
Old Mar 26, 2010 | 03:57 PM
EeF's Avatar
EeF
Thanks. I'll check this out also
Old Mar 26, 2010 | 05:01 PM
sirtef9's Avatar
Check your half shaft
Old Mar 26, 2010 | 05:07 PM
EeF's Avatar
EeF
I have changed the half shaft also.Thanks for the suggestion though.
Old Mar 26, 2010 | 05:52 PM
rexracer626's Avatar
i had the a similar problem with my crx i changed my inner and outer tie rods and my mounts and it worked out but it could be anything really hope you find it man i know the feeling
Old Mar 26, 2010 | 09:06 PM
EeF's Avatar
EeF
Thanks man. Im going to change the tie rods and probably change the wheel bearings. Hopefully this will fix the problem.
Old Mar 28, 2010 | 03:21 AM
EeF's Avatar
EeF
Bump for any other solutions
Old May 31, 2010 | 12:36 PM
Rob.'s Avatar
Radius rod bushings.
DavidDb1
Apr 25, 2016 05:19 PM
track_assassin
14
Apr 27, 2006 12:14 AM
sohctodohc
Mar 5, 2006 09:54 PM
blub16hatch
Mar 7, 2005 09:02 PM
shorty91
Nov 22, 2004 06:46 PM
