wiring harness
Old Mar 26, 2010 | 11:39 AM
rustanghunter's Avatar
Default wiring harness
i am finally doing the swap ive wanted to for years im putting a b18c1 in my hatch,
quick question though i cant seem to find an answer, will the stock b18 motor harness work after i put the engine in my car? or will i have to buy a new harness for the swap? i looked at the rywire harness but i was wondering if i could make this work for little or no extra money
Old Mar 26, 2010 | 11:46 AM
lunalink's Avatar
Default Re: wiring harness
you have to use the one that's in your car
unless you plan on chaning your entire cabin harness
Old Mar 26, 2010 | 12:06 PM
ChokolAwt's Avatar
contrary to popular belief its much easier to use the existing harness and modify/extend wires to fit the engine you're trying to run.
do you have an obd0 to obd1 conversion harness? ecu?
Old Mar 26, 2010 | 03:33 PM
the motor is coming out of a whole car so ya ive got the ecu but no conversion harness
Old Mar 26, 2010 | 05:04 PM
black0hatch's Avatar
why is this contrary to popular belief? its what you have to do. unless like some one allready said your gona change then entire car harness to match the gsr engine harness.
Old Mar 26, 2010 | 05:26 PM
Je2RiT's Avatar
yea. while you have the motor out would be the best time to rework all the wires.
Old Mar 26, 2010 | 05:38 PM
rexracer626's Avatar
i have a obdo-obd1 jumper if ya want it pm me
Old Mar 26, 2010 | 07:58 PM
so i use my si harness modified, and use the obd0/1 jumper to connect it to the ecu?, sorry im a pretty good mechanic but im not the greatest with wiring
Timothy Yhtomit
Feb 26, 2019 02:25 PM
CRX_Honda
Nov 14, 2008 05:06 PM
bbrian
Oct 22, 2005 11:18 PM
streetmodified
Jan 6, 2005 01:49 AM
