OB2 And C.A.N Scanner C.E.L Resetter. (California)
SOLD!
I prefer local cash deals. I will accept paypal to ship if you'll add an extra $10.00. E-mail me I.Work.With.Cars@GMail(dot)Com thanks.
According to the box this tool is able to display live data from your car's computer, such as current RPM, engine coolant temperature, vehicle speed, oxygen sensor data, and much more.
This scanner works on all five OBD II protocols:
* SAE J1850 - PWM
* SAE J1850 - VPW
* ISO 9141-2
* ISO 14230-4 - KWP 2000
* ISO 15765-4 - CAN (Controller Area Network)
Main Features:
1. Work with all 1996 and newer cars & trucks -- US Models, European, Japanese, Asian, German, Korean...
2. Support all five OBD II protocols: CAN Bus (Controller Area Network), ISO 9141-2, ISO 14230 (KWP2000), SAE J1850 PWM , SAE J1850 VPM
3. Read both Generic and Manufacturer specific Diagnostic Trouble Codes.
4. Display the detailed description of the trouble code on a large all-in-one LCD.
5. Retrieve pending Diagnostic Trouble Codes even if Check Engine Light is not ON.
6. Read Live Data:
* Fuel System Status
* Coolant Temperature
* Short Term Fuel Trim
* Long Term Fuel Trim
* Engine RPM
* Vehicle Speed
* Intake Air Temperature
* Absolute Throttle Position
* Second Air
* Oxygen sensor value
7. Read Freeze Frame Data.
8. Read Vehicle Information including VIN #.
9. Check monitor status, make sure all the monitors completed their diagnostic testing and verify if the repair was completed properly.
10. Turn off Malfunction Indicator Light (MIL) /Check Engine Light.
11. Clear stored codes and reset monitor status.
12. 9V Internal battery backup for off-car display.
13. Dimension: 188×82×30 mm
14. One year warranty.
Package Includes:
* TP-180CAN OBD-II Code Scanner.
* Data Link Connector (DLC) Cable.
* User Manual.
* Software CD.
* Soft Nylon Case.
* I9V Internal Battery (Installed).
* SAE J1850 - PWM
* SAE J1850 - VPW
* ISO 9141-2
Main Features:
6. Read Live Data:
* Engine RPM
* Vehicle Speed
* Second Air
Package Includes:
* User Manual.
* Software CD.
* Soft Nylon Case.
