Help Idle Problems!!!!!!!!!!!!!!!!
Old Mar 25, 2010 | 10:56 PM
TackOut27's Avatar
Default Help Idle Problems!!!!!!!!!!!!!!!!
i have a 99 civic ex sedan with a 95 integra ls swap. (OBD1) ok here is my problem when i am idling ok when i stop at a traffic light, or stop sign my car (RPM'S) rev. up and die down!!!!!!!!!! can a exhaust leak between the header and down pipe cause this? or if not what else should i be looking for? thanks
Old Mar 26, 2010 | 04:43 AM
ChokolAwt's Avatar
Default Re: Help Idle Problems!!!!!!!!!!!!!!!!
an exhaust leak wont cause an idle problem. unmeter air entering the engine is what causes the idle to surge... your iacv could be bad or you could have a gnarly vacuum leak.
iirc when you take off your intake there should be 2 holes on the back side of the throttle body on the inside. i think if you cover the top one with your finger and the idle fluctiation ceases then your iacv is bad. you could try cleaning it
Old Mar 26, 2010 | 07:03 PM
TackOut27's Avatar
thanks you replied to my other post. about the valce clearance. i gaped the intake side to .005 and the exhaust side to .008 and then from there i just messed with the dizzy and BAMM!!!!! it runs like a top. idle problem is right at 900 (RPM) thanks....
Old Mar 26, 2010 | 07:22 PM
drtysoufchevy's Avatar
try unplugin your o2 sensor and if the car runs fine replace it.
DO/\/\O
14
May 9, 2011 05:56 PM
GreenMachineRex
Sep 22, 2005 03:12 PM
lilCivic
Feb 2, 2005 05:36 PM
99shRIGGS
Dec 23, 2004 08:34 AM
Merilious
Jul 2, 2004 06:19 PM
