OBD1 Injectors with DPFI-->MPFI Swap
Old Mar 25, 2010 | 07:06 PM
4d00rEF's Avatar
Default OBD1 Injectors with DPFI-->MPFI Swap
Alright, so ive about got what i need around for my MPFI swap.
My question i want to be SURE of, is that since im using obd1 injectors, what do i do with the wires that would normally go to the resistor box?
From what ive read, you just solder them together. But then what? Run them to the yel/black wire at the drivers side engine harness? Which is pin a15 at the ecu, right? So, could i just depin a15, and solder all the wires together, to one wire, and run that wire to a15?
This is the only part thats confusing me.
Old Mar 25, 2010 | 09:01 PM
Echo 6's Avatar
Default Re: OBD1 Injectors with DPFI-->MPFI Swap
When i added newer injectors to my rex i just de pinned the plug on the harness and plugged the pins into an integra dead plug, which connects all the wires together, like if you solder them. The yel/blk wire is plugged into the dead plug too, so it is connected to the rest & wired to the ECU. The only part i am fuzzy on is this; do you already have the yel/blk wire running to your ECU? On my Si it goes there from the factory, but maybe it's different on a DPFI
Old Mar 26, 2010 | 03:26 AM
Jenkinsal2's Avatar
you need all the grounds from the injectors to connect to pin A15. You can do this however you want. Your method will work.
89ED
Jan 20, 2017 05:37 PM
Ryan559
Nov 5, 2010 07:41 PM
mra4886
Oct 17, 2007 12:20 PM
pm41
Sep 7, 2005 12:18 AM
Exempt
May 25, 2005 04:10 AM
