Honda S2000 Honda S2000
Headlight went out HELP..
Old Mar 25, 2010 | 02:36 PM
johnnynguy3n's Avatar
Default Headlight went out HELP..
Hi, yesterday night i was driving home and my headlight just suddenly turned off on me. my high beam doesn't work either so i try to checking the fuse and relay it all look good but the headlight fuses (20A Fuse) there no power going to these 2 fuses. The only light that works is my parking light. Does anyone know what happen and how i can fix it?
Thank You
Old Mar 26, 2010 | 09:46 AM
Default Re: Headlight went out HELP..
bumpp
Old Mar 26, 2010 | 10:00 AM
90Rexx's Avatar
uh oh... sounds like a wiring issue, only one side high and low beam??
try unplugging your headlight, and plugging it into the other side, just to verify the bulb is good.
then start tracing power back to the switch, and go from there
Old Mar 26, 2010 | 11:15 AM
White Smoke's Avatar
i my honda
Global Mod
You are 100% sure you have no power going into the fuse?
Old Mar 26, 2010 | 11:35 AM
yes i am 90% there no power going to the headlight fuses. (i power tested it) Only the parking/signal lights work other than that nothing else work. i try my friend headlight and it still didn't work.
Old Mar 26, 2010 | 06:34 PM
bump
Old Mar 27, 2010 | 05:13 AM
90Rexx's Avatar
if your capable enough to trace power, start at the headlight socket, and go all the way back through the fuse box, into the switch, and all the way back to the power source. if your not compitent enough to do that... bring it to a dealer :-\
Techvegas
Dec 12, 2019 10:00 AM
Nick Rickard
May 13, 2018 02:27 PM
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
Manny 77
Mar 18, 2013 11:37 AM
