Auto to manual conversion
Old Mar 25, 2010 | 12:37 PM
Adrian91's Avatar
TRIAL USER
Default Auto to manual conversion
I might buy a 93 dx hatch. It has a d15b7 auto trans. I'm looking to do a manual swap. But later down the road im looking to do a B swap. The guy has the pedal assembly, shifter, linkage. Is it hard to do that swap? Later down the road im doing a B swap. I know im going to need a different shifter linkage cable. What im looking for is some info on if its really hard. Or even better, a DIY link, i searched google and couldnt find anything.
Old Mar 25, 2010 | 12:41 PM
RagnarX's Avatar
Default Re: Auto to manual conversion
Its not hard if you have the time and some mechanical skill. I did it over 2 weekends, had to wait on parts.
Here's a tip I always use since honda-tech's search function sucks ***** nowadays. type what your looking for in google then right after that type site:honda-tech.com
this is the main thread I used:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-my-auto-manual-swap-pics-56k-no-no-2090074/
Old Mar 25, 2010 | 12:49 PM
Adrian91's Avatar
TRIAL USER
damn man thats a big help thanks a lot
Old Mar 25, 2010 | 12:58 PM
RagnarX's Avatar
np. The hardest part was installing the manual pedalset. such a pita to get it in there without removing/dropping the steering column. Everything else should be a breeze.
Old Mar 25, 2010 | 01:02 PM
Linked's Avatar
IMO the hardest part was DCing the shifter assembly from the bottom of the car,
the bolts will be rusted and 99% of the time they will round out, i had to get vice grips on em but the exhaust pipe was in the pipe, and i didnt want to spend more time removing it.
but one thing i thought about, if your swapping to a B and you have the auto bracket on the trans side,
that might need to be cut off and a true manual bracket must be welded there,
so if your going B soon dont get the conversion mount, get the manual tranny mount and bracket to the chassis.
Old Mar 25, 2010 | 01:11 PM
RagnarX's Avatar
the conversion mount works for both D and B series trannys. A must have for this swap if you dont want to weld in a manual pocket mount.
Old Mar 25, 2010 | 01:17 PM
94EG8's Avatar
Seagull Management
It really doesn't matter. '94 - '01 5 speed Integras and '92 - '95 5 speed Civics use identical upper transmission mounts, therby the auto to manual mount works the same. I always replace the bracket with the manual version and welded it on, but I have a welder, and i'm cheap. If you don't have a welder then it may be more cost effective to buy a swap mount. H22 swaps do require welding on the manual bracket though, perhaps thats what you were thinking?
Marvlus_
Sep 7, 2011 12:14 PM
pstoner
Honda Civic (2001 - 2005)
Nov 5, 2009 04:59 AM
b12
Apr 30, 2004 04:40 PM
94hatchback
Mar 24, 2004 06:15 PM
