Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
wierd winding noise
Old Mar 25, 2010 | 11:29 AM
em2-matt's Avatar
Default wierd winding noise
im hearing this winding noise in my car, but it only makes it if the radio is on. my friend said it could be from a bad ground to the radio but i've checked most of the grounds and they all seem fine. any ideas?
Old Mar 25, 2010 | 05:31 PM
It Wasn't Me's Avatar
Default Re: wierd winding noise
Stock or aftermarket radio system? Does the whine change as the RPMs go higher and lower?
Probably a bad ground, or you've run your RCA wires too close to the power cable.
Do you experience any other problems with the radio?
Old Mar 25, 2010 | 07:35 PM
em2-matt's Avatar
stock radio and i haven't done any wiring, but the previous owner did an ipod hook-up and xm radio hook-up and the noise gets a little louder as the RPMs increase
Old Mar 25, 2010 | 08:28 PM
Maple50175's Avatar
same problem here, its super annoying.
Old Mar 25, 2010 | 11:20 PM
red02ex's Avatar
1st its the sound of your alternator threw your speakers (generaly)
2nd up grade the big 3 grounds should take that problem out
try thats how i fixed mine
Old Mar 26, 2010 | 08:29 AM
em2-matt's Avatar
thanks ill try this and see if it fixes the problem
daveymcgav
Audio / Security / Video
Feb 6, 2017 03:52 PM
skingfreak
Aug 29, 2006 05:44 PM
hookedonvtec
18
Oct 20, 2005 06:42 PM
ablack934doorcivic
Jul 9, 2005 07:39 PM
Soundwave
Aug 19, 2003 06:14 PM
