D15B2 heating problem. HELP!
Old Mar 25, 2010 | 09:37 AM
EnviedByMany's Avatar
Default D15B2 heating problem. HELP!
I just bought a 90 CRX yesterday with a D15B2.
I knew it needed a clutch, and thats something im
pickin up today. But all of a sudden started heating up.
im like WTF! Everything seems fine,
water pump aint leaking, radiator is full.
Thermostat? any ideas?
and also my idle is jumpy. from 1k-2k.
worth fixing?
+200xxx miles. on it.
Old Mar 25, 2010 | 09:42 AM
Default Re: D15B2 heating problem. HELP!
The fans turn on once it gets to half way.
Old Mar 25, 2010 | 09:48 AM
lunalink's Avatar
head gasket? thats what i just did to mine. put new rad.hoses.coolant. and still heating up.
i haven't turned it on still need to put the timing belt on
Old Mar 25, 2010 | 09:58 AM
JacksonD's Avatar
bump, where on the temp gauge should the needle be? mine only ever gets up to about a quarter up, i know on newer cars the temp stays at half way, but mine never gets thtere i replaced my thermo as well or is that normal to have the temp gauge at only a quarter
Old Mar 25, 2010 | 10:05 AM
k20rex's Avatar
id say start with a thermostat it may not be opening and its the eaziest and pretty cheap place to start, if that does not fix it probally the head gasket do you have coolant in the oil? the idle problem could be lot of thing one of them is low coolant level, iacv could have carbon build up, or maybe a vacum leak
Old Mar 25, 2010 | 04:46 PM
No coolant in oil. No water leaks anywhere. I think its the thermostat
weekendboost
Jun 21, 2019 06:11 PM
DTHADDR
11
Feb 5, 2013 12:28 AM
CRXracer88
Jan 25, 2004 11:18 AM
