ETD radiator V.S. full race radiator
Hi Hondatech,
I found a thread, searching last night. The fluidyne crx half radiator is only a civic radiator. So it won't clear the hood.
I found these two radiators
ETD
http://www.etdracing.com/store/produ...products_id=76
Full race
http://www.full-race.com/catalog/pro...roducts_id=481
I found nothing on the etd radiator
though I found threads on the full race radiator saying it leaks, overheats, and is; "only suppose to be used for drag racing"
Which I don't understand why
So, does anyone have any personal experiance with these two brands?
And if someone could post the dimensions of the radiators
That would also be cool
Also; Can you use OEM radiator caps with these?
I'll go ahead and post some info on the radiators I know about
Maybe we could place this in the faq?
Mishimoto:
OEM fit, dual core
Will not clear factory cross member
Can use OEM radiator cap, comes with a radiator cap
Fluidyne half size:
FHP11-88CRX.5 is a narrower radiator than stock for ’88-’91 Civics and CRX. It is 14.346 inches wide and 16.5 inches tall (excluding filler neck and mounting pins). It will not bolt directly to the original mounts in the stock location. Installation of part number FHP11-88CRX.5 in ’88-’91 Civics and CRX’s will require the mounting brackets to be relocated from the stock location to accommodate the narrower width. Exactly where the brackets need to go will depend upon where the extra clearance is needed on your particular application. This radiator also is designed to use a ’92-’00 Civic fan package.
Will not clear hood or innovative competition bar without modification
Uses OEM radiator cap, comes with radiator cap
KOYO:
OEM fit
Can only use Koyo radiator cap
Full race Half size:
ETD half size:
Edit; something happened to my title, can the mods please fix it?
It was suppose to be ETD V.S. full race radiator
Hi Hondatech,
ETD
Full race
Mishimoto:
OEM fit, dual core
Fluidyne half size:
KOYO:
OEM fit
ETD half size:
acmoc
22
Jan 29, 2012 02:38 PM
