just got 92 integra front brakes have some ??????
Old Sep 9, 2002 | 08:12 AM
KevronsEG's Avatar
Default just got 92 integra front brakes have some ??????
whtacane i use off them and whta do i need from other cars i have the hole front everything. do i use the calipers and rotors but get some ex hubs/spindles or what. thanks guys. ps shoul di get cross drilled of oem form brembo (sp)
Old Sep 9, 2002 | 08:14 AM
ijjz's Avatar
Default Re: just got 92 integra front brakes have some ?????? (CIV616)
Get brembo blanks, and I believe you can use the integra's spindles but I from rumors and mythology they say the integra's spindles can throw the suspension geometry off. I would recommend just getting the Civic EX 4-Door spindles just to be safe.
Old Sep 9, 2002 | 08:17 AM
ijjz's Avatar
Default Re: just got 92 integra front brakes have some ?????? (ijjz)
Also, if you do not have the stuff already. Then just get all the peices from the Civic EX. It will make it alot simpler, and pieces will more then likely equally aged. That way you dont pair up something that does not exactly match if you see what I'm trying to say.
1.5Slowmatic
Suspension & Brakes
Sep 23, 2010 06:09 PM
Jonathan_ED3
15
Apr 1, 2004 09:27 AM
Sleek98
May 7, 2003 11:26 AM
UltRaH22
Mar 6, 2003 11:07 PM
