need help with 96 integra with 94 gsr motor
Old Mar 24, 2010 | 11:15 AM
whitaker_1991's Avatar
Default need help with 96 integra with 94 gsr motor
I have a 1996 Acura Integra swapped with a 94 GSR. With an OBD1 ECU I am throwing up code 4, code 6, and code 22. With an OBD2a ecu I am throwing up code 54. My car is not drivable and at idle it revs from six to nine hundred back and forth and when you give it gas it dies after 2500 rpms. What is going on?
Thanks
Old Mar 24, 2010 | 11:45 AM
Acuronda_SloTeg's Avatar
Default Re: need help with 96 integra with 94 gsr motor
ecu crapped out? my homeboy has the exact same thing and his obd2 works on it fine, and the obd1 does too. if you are throwin random mixmatched codes on both ecu's it could also be wiring
turboITR#704
Sep 10, 2005 05:09 AM
Vera
May 22, 2005 11:00 PM
AzNpRiD3
May 14, 2004 06:05 PM
