Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03' vs 04' vs 05' Accord
Old Mar 24, 2010 | 10:02 AM
Honda-Tech Balla's Avatar
Team Purple
Default 03' vs 04' vs 05' Accord
Are there many differences that I should know about between these? Between 03, 04, and 05?
I figured I come here and get the true owners details from my fellow HT peeps since they won't steer me wrong with BS info I'd find online, Thanks in advance fellas
Old Mar 24, 2010 | 10:40 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: 03' vs 04' vs 05' Accord
I don't personally know of any significant differences.
But I'd personally tell you to try like hell to find a 2006.
Old Mar 24, 2010 | 11:21 AM
GoLowDrew's Avatar
Old Member
25 Year Member
X2. There is "no difference" between 03-05 now that you are searching for a used car.
The mid-model change was in 06. New lights, wheels, trunk lid, bumper, exhaust outlet, and DRL.
As a former owner of a 06 EX, it was the "most perfect" Honda I ever owned. Solid and never a rattle even thou we beat it DD. Oh, except for the rear brakes wearing out too fast. First sign of corporate cost cutting(?).
Old Mar 24, 2010 | 11:34 AM
Team Purple
So I guess it sounds like I should shift my attention to the 06's as per both mods!
Thanks guys
Old Mar 24, 2010 | 11:46 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
For performance(don't know if you're looking for the v6) you have to note that there was the small difference in HP output starting in 06 for the v6 Accords, and also 06-07 model years were the only one in the generation with the 6 speed available in the sedan model. According the trap times etc. over at veesixperformance.net there is a noticeable difference between the 03-05 and 06-07 6-6 coupe power.
I owned an '05 and it came with the crappy clutch master cylinder(there is a TSB on it), so they hadn't fixed that issue as of '05 model years apparently. I don't know of any technical differences between the three first years of the 7th gen Accords. I do know that I absolutely loved the car overall, and if I decide to buy a car in that price range soon, that is at the very top of my short list of possible purchases, even though and because I have already owned one
If you're looking into the four cylinders, AFAIK they aren't really slouches with the five speed, breaking into the 14s with basic bolt-ons, and running about a 15.7 stock, which is on par with EP3s/base RSX(due to the increase in tq with the K24). I am not sure if the significant increase in I4 HP came in 06 or for the 08 generation though.
Old Mar 24, 2010 | 02:55 PM
BLKFLSH's Avatar
I have an 03 V6, and I don't have any problems with it. I think the later models actually have more recalls than the 03 did.
Old Mar 25, 2010 | 09:51 AM
PowerUser's Avatar
03-04's were pretty much the same. 05's changed the rear brake lights from red/clear (03-04) to pretty much completely red in 05.
In 06 there were some subtle and some not so subtle changes. My favorite changes being the much improved rear brake lights and bigger brakes up front for the 4 cylinder models.
If you're looking to buy, go with the 06-07 models. IMHO They are the best accord ever made. I liked it so much I bought one
Old Mar 25, 2010 | 10:30 AM
Team Purple
Thanks to everyone for the info much appreciated
Team Purple
Were they serious recalls, or...?
Old Mar 25, 2010 | 10:43 AM
Which model were you looking into buying? IIRC there are few, if any "recalls" for the Accords. What Honda does, which is exemplary of an arrogant company, is simply release a TSB for everything that is documented to go bad... even if it is across the entire VIN/year range. There are a couple TSBs for the 6-6 Accords, including the clutch master cylinder, which is known to fail, and the third gear pop-out. What Honda tells you, is if your car is under warranty, they'll fix it... and if it's not, they tell you they are "unable to recreate the problem" or some other line of BS, or that you're 100% liable for something that I'm sure the domestic companies would simply recall to save face.
Old Mar 25, 2010 | 05:32 PM
xstrike393x's Avatar
TRIAL USER
Icon2 Re: 03' vs 04' vs 05' Accord
Just got a 2003 Accord Coupe 2.4L and was wondering if there were things that I should keep an eye out for and also if there were any mods I could do to increase performance without spending so much. would really appreciate the help.
Old Mar 25, 2010 | 06:22 PM
4gen5thtime's Avatar
Get a intake, and a cat back to start. Then down the road a header. You will love it. And good way to thread jack first post home boy.
Old Mar 25, 2010 | 11:54 PM
Team Purple
Thanks! and about the hijack I agree again +1
Old May 7, 2010 | 05:32 PM
np04accord's Avatar
i own an 04 accord v6 and if your looking to get performence parts do not get an 04 it is close to impossible to find parts.
Old May 7, 2010 | 07:25 PM
BLKFLSH's Avatar
The 04 added XM radio, the 03 didn't have. In 05 I think the V6 hybrid was introduced, and the tail lights went all red. That's the only differences I know of. They claim the 03-04 models have more transmission problems, but I have been seeing more and more 06 models with the same problems, now that the miles are adding up on them. My 03 V6 transmission is doing better than some 06 V6 transmissions with less miles on them. All I can say is change the transmission fluid often, and don't abuse it, regardless which year it is.
Old May 13, 2010 | 06:56 PM
poetik02's Avatar
I have an 03 v6-6 with navi and notice that it doesn't say "premium audio system" on it like other 04+ accords with navi. does it have to be an EX-L? i think mine is just an EX.
i wonder how much better it is.
lee0149
Audio / Security / Video
Feb 23, 2009 07:58 AM
asleepz
Jan 13, 2006 01:00 PM
