d16z6 eng and trans in a ef hatch
can anyone with experience on this swap give me a hand please.i have the hasport cable to hydro conversion kit , but the drivers side mount is tilted toward the front of the car. i talked to someone at hasport and he said i need the block post off of a d15b7 and one of their mounts #efd2lh? has any one done this? i havent found info on this specific set up.
I had the same issue when i first swapped in my z6.
from the looks of it the trans bell housing has the eng tilted. that seems to be why it lined up with the cable trany.does any one know about this or are the angles the same?
Maybe hasport has a mount for the cable to hydro conversion.
the guy at hasport says he has a driver side mount for this set up. but i want to find out if anybody has used it and how it turned out before i spend more money on this trans. i might just sell the conversion kit and get a zc trans from tigerjapanese. i purchased the kit because it was cheaper than the zc and i already had a trans from my coupe.
OK I have all the eng mounts bolted in. the eng is sitting in the bay and it looks like i will have to trim some of the crossmember so the rear eng bracket will not touch. the driver side mount is tilted worse than it was. i barely got the bolt in. after all this the wiring seems easy
123HondaFan
29
Feb 23, 2013 04:10 AM
Barbantus
Jul 9, 2010 03:28 AM
