Suspension & Brakes Theory, alignment, spring rates....
rear lower control arm bushings?
Old Mar 23, 2010 | 06:08 PM
kasperxtcy's Avatar
Default rear lower control arm bushings?
i was wondering where i can buy some rear lower control arm bushing... i installed the lower control arms like 2 months ago... but then it started squeakkkkkk....y every time i hit a bump. took them off and realized the bushing are gone... called some places but they dont have the bushings...
i need all three the one on the subfram shock and when it bolts up to the trailing arm...
Old Mar 23, 2010 | 06:38 PM
SoFlaNut's Avatar
Default Re: rear lower control arm bushings?
Try Advance Auto Parts - I just replaced my bushings for the rear shocks. Also Majestic Honda has good prices on parts online.
Old Mar 23, 2010 | 07:15 PM
STOCK_SOHC_DX's Avatar
What kind of LCA's did you install?
Old Mar 24, 2010 | 05:44 AM
phunhaus's Avatar
This is an important question because they don't all use the same size bushing when you get into aftermarket arms.
Old Mar 24, 2010 | 09:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
This is what you get for using cheap POS LCA's, they come with cheap POS bushings.
Stock or Function7 IMHO, heard Skunk2 LCA's are okay, too. F7's have custom-made bushings by energy suspension, with a lifetime warranty from F7, and are easily replaceable without a press. Doesn't get much better than that.
JZiggy
Honda CR-V & Element
Dec 14, 2017 10:24 AM
AZ-Accord
Jan 9, 2013 05:23 PM
SPOOLINmatt
Suspension & Brakes
21
Dec 22, 2010 03:40 PM
jvc7065
Suspension & Brakes
Aug 29, 2007 04:11 PM
Slvr_CRX
Apr 24, 2004 04:22 PM
