91 cb7 stero removal help
Old Mar 23, 2010 | 02:59 PM
f22a1 ftw's Avatar
Default 91 cb7 stero removal help
okay i havnt attempted to remove it yet but i remember on my buddys 93 accord years ago there was a bolt in the back holding it in and i cant remember where it is so i was i hoping if youngs could help me remove it so i could install my new headunit so yea thank you
Old Mar 23, 2010 | 03:17 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: 91 cb7 stero removal help
Sticky: ► 1990-2002 Accord FAQ > Radio Install Guides 4th gen
Old Mar 23, 2010 | 03:26 PM
f22a1 ftw's Avatar
hmm it wont let me open it i downloaded it then it reid to open a ie then said open/open folder/cancel none would open it so yea stil need help
Old Mar 23, 2010 | 04:08 PM
Then you need Adobe PDF Reader
Old Mar 24, 2010 | 07:44 PM
fleetw00d's Avatar
Assuming you have the factory radio with pocket underneath (no CD player), basic steps are:
- Remove the console
- Remove the ash tray
- Where you removed the ash tray, remove 2 (maybe 3?) screws into the bracket underneath the pocket. These are vertical, you'll need a short screwdriver. Tip - put a rag over the open space where the console was in case you drop a screw.
- Slide the radio and pocket out together enough to reach behind and disconnect the antenna cable and harness
Old Mar 24, 2010 | 08:26 PM
uberEFtuner's Avatar
If you are lucky someone else has already installed one. In that case put your fingers in the tape slot and the pocket and wiggle the heck out of it. Sometimes this works.
Otherwise use an 8mm socket with an extension and a right angle tool. Peel back the carpet and get right up behind the radio. That's how I do it, but install for a living though. Its not easy but its fast!
yomayo
Nov 22, 2006 05:11 PM
accord06
Sep 3, 2006 01:17 PM
jjs316
Apr 20, 2006 09:20 PM
friscorice88
Dec 13, 2005 08:40 PM
