IL fully built 92 honda civic si hatchback GT40r turbo 11000obo !!
i got a 92 honda civic si hatchback turbo fully built h23 pictures and description of car are below no bs no low ballers also no joy rides. if you are interested or any questions please call or text call after 3 and text whenever 1 708 663 6872 Mike price is negotiable give me your offerssssss!!! also if needed will get more pictures will try to pm back as fast as i can.
car is really fast on 8psi car made 380hp this car can easily make 600hp on better tune and more boost
redline 7500rpm
2 step 5000rpm
i did run the car once on low 8psi 60ft 1.679 1/4th 11.786 mph 118.08 (this was on 8 inch slicks)
Body-
1992 civic si hatchback
painted mint 2000 si blue the right way
roof is painted black
quaterpanels and roof are brand new from honda whole thing was cut out and welded
fully welded 12 point roll cage
sparco red racing seats
nerg racing wheel with quick release hub
flat black rota slipstream wheels
carbon fiber hood with painted black sides
carbon fiber duckbill
also on the car but not shown in pics the front bumper
hids 10k
amber corner lights
Block-
h23a1 closed deck block
sleeved by golden eagle
bored out to 87.5mm
carrillo rods
cp pistons 9:5:1
acl bearings
cleaned and micro polished h23 crank
arp head studs
arp main studs
cometic head gasket
Head-
h22a euro r head
port and polished head
euro r intake manifold
euro r cams
skunk 2 retainers
skunk 2 dual titanium springs
ferrara valves
all new valve seals
Drive train-
jdm h22a tranny
oem lsd
act fly wheel
compititon stage 5 clutch
gator stage 2 axles
hassport mounts
arp clutch and fly wheel screws
Suspension-
full ksport coil overs
skunk 2 extended lug nuts
skunk 2 extended wheel studs
all new oem wheel bearings
upper skunk 2 control arms
lower skunk 2 control arms
new ball joints
new tie rods
stainless steel braided brake lines
hawk pads
bremo rotors
fuel system-
aeromotive a1000 pump
aeromotive filter
aeromotive fpr
precision 1000cc injectors
10 gallon plastic cell
stainless steel fuel lines
all earl fittings
always on 110 racing fuel
turbo kit-
T4 garrett gt4088r
ram horn manifold
4 inch side exhaust
steel braided coolent lines earl fittings
stainless steel oil lines with oil restrictor
2 1/2 inch custom piping
tial red bov
tial 44mm wastegate
850hp precision intercooler
turbo xs boost controler
electronics-
hondata s300
autometer boost gauge
autometer oil temp
greddy turbo timer
aem wideband
3 bar gm map sensor
http://i480.photobucket.com/albums/r...0312-17011.jpg
http://i480.photobucket.com/albums/r...0312-17021.jpg
http://i480.photobucket.com/albums/r...0929-17551.jpg
http://i480.photobucket.com/albums/r...0929-17561.jpg
redline 7500rpm
2 step 5000rpm
Body-
hids 10k
amber corner lights
Block-
bored out to 87.5mm
carrillo rods
cp pistons 9:5:1
acl bearings
arp head studs
arp main studs
cometic head gasket
Head-
h22a euro r head
euro r cams
skunk 2 retainers
ferrara valves
all new valve seals
Drive train-
jdm h22a tranny
oem lsd
act fly wheel
gator stage 2 axles
hassport mounts
Suspension-
new ball joints
new tie rods
hawk pads
bremo rotors
fuel system-
aeromotive filter
aeromotive fpr
all earl fittings
turbo kit-
T4 garrett gt4088r
ram horn manifold
4 inch side exhaust
tial red bov
tial 44mm wastegate
electronics-
hondata s300
autometer oil temp
greddy turbo timer
aem wideband
3 bar gm map sensor
i blew the motor on the dyno brought that car home pulled the swap took every thing apart and someone broke in and stole the turbo kit the tranny clutch and my slicks and rims that where laying on the side
eh i guess the police dont same much to me cause they can tell its a fast car i have a cage in it and always wear the harness so they leave me alone pretty much and only 7500 because my tunner said the tranny wont hold over 7500 rpms
weirdocolorEJ
Oct 1, 2012 07:07 PM
aem
Apr 2, 2010 12:46 AM
HomeBuilt
19
Aug 10, 2005 11:49 AM
