DIY solid motor mounts?
Old Mar 23, 2010 | 02:02 PM
alx_90ef's Avatar
Default DIY solid motor mounts?
whats that one silicone that you can use to make your own solid motor mounts?
Old Mar 23, 2010 | 02:17 PM
Jenkinsal2's Avatar
Default Re: DIY solid motor mounts?
McMaster has some poly products that you can use. I'm pretty sure you are thinking of window weld though.
Old Mar 23, 2010 | 02:45 PM
alx_90ef's Avatar
yeah it was something like that b4 but i forgot what is was
Old Mar 23, 2010 | 04:06 PM
HondaPartsHero's Avatar
Technical Hero
http://www.jdmuniverse.com/forums/ho...or-mounts.html
Old Mar 23, 2010 | 04:44 PM
alx_90ef's Avatar
thanks thats what i was looking for
Old Apr 29, 2010 | 10:35 PM
EKwreckRLS's Avatar
has anyone done this to mounts that were in pretty bad condition?
I have a few other mounts to try this on, but they are worn!
Old May 9, 2014 | 11:03 AM
smichka's Avatar
is it bad to do this just to one or two motor mounts?
will it break other mounts ?
i've just did my left mount,tomorrow gonna do the 2 smaller mounts and the others 2 gonna stay stock
Old May 9, 2014 | 12:38 PM
ef-hatchcrap's Avatar
Why don't you just get energy suspension motor mount inserts?
Old May 9, 2014 | 12:56 PM
4drEF's Avatar
Keyboard Humorist
Because you can do the job for $40 or less with 2 tubes of Window Weld and not end up with squeak or lube maintenance that often accompanies ES mounts.
Old May 9, 2014 | 02:32 PM
smichka's Avatar
I don't want track stable engine,just a little stiffer then stock and also hate rattling enterior
Old May 9, 2014 | 03:14 PM
KevinEF7's Avatar
Window weld is what you want if you can put up with a little bit of vibration, inserts vibrate much more, and 70a poly mounts youre girlfriend is basically squirming in her seat the engine resonates the car/steering wheel/rear view
One tube of window weld will do 3 mounts. Dont cheap out and buy pl premium or caulking or anything stupid like that, if youre going to fill them, fill with window weld
Old May 10, 2014 | 02:50 AM
smichka's Avatar
I filled it with some other window weld poly hardness 50-55A that's near rubber but the whole mount is now full so there is no room for play,i'll see what gonna happen in 2-3 days when i'm gonna mount it
Old May 10, 2014 | 05:55 AM
Vagitarian's Avatar
Only 3m makes a product called window weld, what did you use
Old May 10, 2014 | 09:02 AM
smichka's Avatar
totalseal 110 for same use different brand,i would buy 3m but local stores didn't had,so this was my alternative
btw hardness 60A and the price just 6$ lol
Old May 10, 2014 | 01:10 PM
KevinEF7's Avatar
Good luck with it, you could have bought the 3m from Napa guess you didnt look there eh
Where did you pull 60a hardness from? I see zero info on the product on the net being used in this application
Old May 10, 2014 | 03:32 PM
Technical Hero
I've also seen people use coolant or fuel line hosing to fill the gaps. Adds a little more support but not the stiffness of window weld.
Old May 11, 2014 | 02:17 AM
smichka's Avatar
dude i'm from macedonia no napa here :D
and the info i got it from www.totalseal.net
Old May 16, 2014 | 04:58 AM
smichka's Avatar
Icon6 Re: DIY solid motor mounts?
And here is my rear motor mount PAIN IN THE *** to take out after 2 hours of making diy tools,and 3 hours moving things so i can get to the mount
so what do u say,will silicone help here or i need new mount,anyone done that bad mount with silicone?
Old May 16, 2014 | 09:37 AM
4drEF's Avatar
Keyboard Humorist
If you can set the metal bushing back to where it belongs (easy), then you will be fine using windowweld to fill the open gaps.
Old May 16, 2014 | 10:03 AM
smichka's Avatar
after all it will cost me huh 3$,and 2 hours work for removing if it breaks
deff gonna give it a try
and yes it's very easy to put it on place cause on the pic the mount is upside down
Old May 30, 2014 | 06:31 AM
smichka's Avatar
After 2 weeks driving the mount looks solid as steel,i think gonna do the job for a long time
ej1gsr!
Dec 14, 2011 09:24 PM
hondaapi
Oct 20, 2008 01:52 AM
white_db8
May 26, 2007 09:34 AM
Bbasso
Mar 4, 2005 05:48 PM
6GACCORDH22
Sep 11, 2002 06:01 AM
