need help
Old Mar 23, 2010 | 10:47 AM
slow_cars_r_us's Avatar
Post need help
i have a 94 delsol vtec(b16a3 model). before it quit working it took a while for the fuel pump to kick on. and it would die on me randomly but it didnt through any codes. so i replaced the fuel pump and the main relay and it still didnt change. now my fuel pump doesnt kick on at all and my cel is on. when i tried pulling the codes it doesn't flash(i made sure i was doing it right) its just solid, and my car doesn't start. i tried changing the relay again, and it didnt change. i have no idea what it could be.
Old Mar 23, 2010 | 11:41 AM
Default Re: need help
also sometime when im stopped, i would have to keep pressing the accelerator to keep it going
Old Mar 23, 2010 | 11:43 AM
civic_r87111's Avatar
Sounds like ur ecu took a dump or has a bad ground. Check the grounds in the engine bay, the main 2 are the thermostat housing ground and the ground strap from the tranny to the chassis. Make sure they r clean and tight!
Old Mar 23, 2010 | 02:08 PM
well i pulled my ecu and opened it and it was burned up so i think thats the problem
Old Mar 23, 2010 | 10:44 PM
That sukx but might as well get a chipped one now.
Bushybob94
Jun 5, 2018 11:40 AM
samsintegra
Jan 3, 2016 01:12 PM
Elgrys.Mendez
14
Aug 5, 2011 01:26 PM
madmax94
Feb 28, 2011 02:03 AM
crxowner
Oct 2, 2007 05:49 PM
