something whistling
Old Mar 23, 2010 | 08:41 AM
ghat98's Avatar
TRIAL USER
Default something whistling
there is something whistling really loud under my hood and i cant find it. it whistles everytime i get on the gas then it will go away. does anyone no wat it could be.
Old Mar 23, 2010 | 09:15 AM
DumaDA's Avatar
Default Re: something whistling
you'll need to post what kind of car you have, motor, if you've changed anything, where the "whistling" sound is coming from, you need to provide is with more information than what you did
Old Mar 24, 2010 | 02:45 PM
LilTeggy2011's Avatar
i have the same problem...i dontnkow whrer its coming from but i suspect from the front of the car
can anyone help?
Old Mar 24, 2010 | 02:50 PM
DumaDA's Avatar
is it sqeaking or whistling, do you hear it with the hood popped or when you're driving the car
Old Mar 24, 2010 | 03:00 PM
dc2LS's Avatar
do u have an aftermarket intake if so thats whats causing that whistling noise
Old Mar 24, 2010 | 06:37 PM
2000_IntegraGS's Avatar
^^I can only imagine that would be the case. I have heard a few different air filters that whistle when you reduce the air flow(let off the gas) Some are louder than others
Old Mar 25, 2010 | 08:01 AM
yes i have an aftermarket intake...
so i should install a new air filter?
Old Mar 25, 2010 | 08:29 AM
I would take the filter off first to see if that changes the sound. then you will know if that is where the sound originates
Old Mar 26, 2010 | 05:11 PM
JbiZ22's Avatar
MIne does the same thing. Im going to get a new filter.
Old Mar 29, 2010 | 04:00 AM
sjbmx's Avatar
the whistling you hear is your intake. its totally normal. theres a reason your stock intake is so complicated compared to aftermarket ones, so there is zero noise. i personaly like it.
Old Mar 29, 2010 | 05:01 AM
mmoore9700's Avatar
I have an CAI and even after I installed a new filter it still whistles, it's normal.
Old Mar 29, 2010 | 08:21 AM
FuNkDrSpOt's Avatar
It's not the intake ( per say ). It's the fact that you no longer have a resonating chamber. You know that thing that was part of the stock intake that was in your bumper?
What really is going on is the air is whistling as it's passing your throttle body. I have an aftermarket TB that has a little bit thicker plate and I don't whistle nearly as much as i did in the past.
avallach
Honda S2000
Apr 21, 2007 04:17 PM
Sean DM
Honda Civic (2001 - 2005)
Oct 10, 2006 07:30 AM
pinecone
10
Mar 26, 2006 08:27 AM
slowww b18b1
Apr 3, 2004 09:40 PM
TyPE-RON
Dec 17, 2002 10:13 PM
