WV -PA FS/FT 1995 GSR Integra DB8...Midori Green!
1995 gsr integra 4dr. repainted midori green by the previous owner, has 160k original miles on the motor/body. I drive it everyday, put 3k trouble free miles on it since the last month. engine runs very smooth, no oil leak/burn oil/coolant/smoking at all. Transmission is okay, B series trannys are notorious for 3rd gear grind, this one has it if you take the rpms really high (above 7k) and shift really fast. I keep it below 3k rpms usually to get good gas mileage, it drives perfect then.
Lowered on Goldline springs and Tokico blues, has white Rota C8's, K&N intake, and greddy exhaust.
It has a new (not reman) drivers side axle ($100), timing belt/waterpump ($60), radiator ($120), fresh syncromesh tranny fluid (friction modified-$40), new resonator ($35), 2 new tires (Hankook K106 - $170), sparkplugs, and others
BAD:
the things wrong with my car are - passenger window rolls down slowly, sunroof glass is cracked up opens/closes fine and doesn't leak, and a tiny bit of rust starting too peek on the passenger quarter panel. no rust anywhere else though. the paint could be better, but like I said the previous guy did it and I haven't touched the paint at all.
$3700 or trade for another Honda/Acura.
B swapped civics, clean civics + money, parts, electronics, I'm open to all offers. PM me please
Bump if viewed!
BAD:
Bump if viewed!
thanks, yeah I got it like 4 months ago. I drove 1000 miles to get it, the car came with an extremely warped rotor :facepalm:. it was literally braking on the metal pad the whole way home. I fixed it all though, I just put in new pads front and back, new rotor up front, new tie rod, alignment.
sde780
Mid-Atlantic (Sales)
25
Apr 9, 2010 02:24 AM
