Etd traction bars vs Full-race
Old Mar 22, 2010 | 04:32 PM
boostedrex605's Avatar
Default Etd traction bars vs Full-race
id like to hear from people running either setups..
How well they are made any problems mounting them ..
im also interested about the radiators they make .. lmk HT!! thanks
Old Mar 23, 2010 | 07:05 AM
KARSON's Avatar
Default Re: Etd traction bars vs Full-race
if your not doing drag racing then dont spend your money on those.
get an innomotive there pretty cheap and work good enough
Old Mar 23, 2010 | 07:09 AM
88Hatchy's Avatar
I've seen bad things about the ETD, and I've heard nothing but good things about the Full-Race.
Old Mar 23, 2010 | 08:06 AM
KARSON's Avatar
Well full race is the most experienced so if u get one of the 2 I would full race Straight up
Old Mar 23, 2010 | 08:23 AM
xalents23's Avatar
I have had my Full Race traction bar for 2 years with no problems at all. And I daily drive my car everyday. It is a straight swap when you take out your old traction bar. You can use your old radiator with this traction bar. Or you can get the half size radiator. Just remember to get an alignment after the traction bar install. If you have the money the full race is a great traction bar to get. They have a lot of great info on there site as well.
Old Mar 23, 2010 | 12:24 PM
rexracer626's Avatar
full race FTW!
Old Mar 23, 2010 | 01:46 PM
CRX Toad's Avatar
You have heard nothing but bad things about the original design. The new design is much stronger and has had no issues. There was a large thread on the ETD bars where the owner of ETD posted and admitted to there original quality being poor and apologizing for it and explaining there corrections made and strengths.
ETD for me personally.
https://honda-tech.com/forums/showth...&highlight=etd
This also has been covered many times check out the search for ETD and Innovative
Old Mar 23, 2010 | 01:52 PM
Coricivic's Avatar
Just ordered a full-race bar yesturday. Back ordered for 20-25 days.
Old Mar 23, 2010 | 02:36 PM
89civicdx's Avatar
I think the new ETD is worse than the old one, mounting such and important part to just tow hook points is horrible...id buy the fullrace or innovative
the 3rd(i think) gen ETD that mounts to the cross member and uses 4 heims on the link tubes is best - if you re-weld the tube in the mount(bad welds)....its great...really simple and strong....have no idea why they changed it
Old Mar 23, 2010 | 02:58 PM
bryse68's Avatar
my friend has a ETD on his crx and it hangs real low....
Old Mar 23, 2010 | 04:00 PM
t_ank's Avatar
just wondering if the new set up has been change so that the brackets line up and you dont have to cut them for the 90 and 91 crx
Old Mar 24, 2010 | 03:25 AM
thanks for all th input! I guess im gonna go with the full-race the car is all out drag.
Sucks that they are back ordered though for 20-25 days!!
anyone have any input on the radiators full-race sells?
Old Mar 24, 2010 | 03:43 AM
2point2's Avatar
You are absolutely right! Tow hooks aren't designed to DRIVE with. Adding the extra arms add a lot of extra strength. The nuts inside the unibody can (and sometimes do!!!) break off - you'll know right away when your alignments goes wacky. My friend had to tack weld his bars on because they were slipping, we were too afraid to tighten the tow hook bolts more as to not strip them.
To this day I've never understood how companies can get away with such terrible designs. Why did people keep buying ETD bars even after they probably almost killed a few people? Honda owners will be anything that's shiny; as long as it's cheap.
Old Mar 24, 2010 | 07:02 AM
88Hatchy's Avatar
Tragic, but very true.
blackstar
Suspension & Brakes
Nov 29, 2009 02:49 AM
turbodailydan
Nov 15, 2009 11:48 AM
killerpenguin21
Dec 15, 2008 04:07 PM
CO_CReX
26
Sep 18, 2008 05:07 AM
benmyfriend
Sep 10, 2006 09:41 PM
