cracked exhaust manifold?
Old Mar 22, 2010 | 04:13 PM
6footmidget's Avatar
Default cracked exhaust manifold?
what causes an exhaust manifold to crack? would it be something thats wrong with the car internally that causes it to crack? or just the general heating and cooling over time
Old Mar 22, 2010 | 04:15 PM
killahatch's Avatar
Default Re: cracked exhaust manifold?
is the manifold your talking about the ones on the dx models? thats a common problem most ek's with the stock manifold have over the years of use. my manifold on my hatch was cracked when i removed the heat shield. no need to worry.
srry if this doesnt answer your question.
Old Mar 22, 2010 | 04:18 PM
how damaging is it to the engine to drive it with a cracked manifold?
Old Mar 22, 2010 | 04:36 PM
CivicSpoon's Avatar
After a while, you may kill your O2 sensor. That will cause it to run rich, which will eventually damage your cat and kill your spark plugs, which will hurt the performance of the engine. Running rich can also eventually "wash out" your cylinder walls, causing abnormal wear on the piston rings.
I've been driving my car with a cracked manifold for over a year; no idea exactly how long because my heat shield was covering it. It's cracked right between the runners, and into the O2 sensor bung. My check engine light just came on about 4-5 months ago; so at least 6 months after I noticed the crack.
You're pretty much guaranteed to fail emissions, because of the false readings it is going to give the O2 sensor.
Old Mar 22, 2010 | 04:42 PM
JarvisW's Avatar
Sol to Sol
You will also burn your exhaust valves there.
My dads car did, and its manifold was cracked between 2-3 and both cylinders had burned em up.
Old Mar 22, 2010 | 04:58 PM
Ruben19's Avatar
get a new one or buy an aftermarket one and eliminate the catalytic convertor thats what i did with my 97 ek hatch and used a o2 simulator to fool the ecu
Old Mar 22, 2010 | 05:18 PM
hmmm im purchasing a car that has a cracked manifold, i need to take it home its about a 30 minute drive on the freeway, would you guys say its safe to do so?
Old Mar 22, 2010 | 05:22 PM
06RSXbase1's Avatar
just keep the window open so you get fresh air
exhaust fumes . . .
Old Mar 22, 2010 | 05:36 PM
DAP97SI's Avatar
I would say it is safe. Honda still has the extended emissions warranty, up to 150,000 miles, if I remember correctly.
Old Mar 22, 2010 | 06:08 PM
vanilla_rice's Avatar
Its normal for a car that age to crack the exhuast manifold and not an indicator of other problems. There's bigtime thermal stresses in an exhaust manifold and it's made of shitty cast iron. Over time it cracks. Depending on how big the crack is there's either no effect or like everyone else said it will crap out your HO2S and screw up A/F ratio and all kinds of crap from there. But driving just long enough to get it home to fix it is nothing to worry about.
Old Mar 22, 2010 | 06:57 PM
would jb weld be strong enough to patch it just for now? i used jb weld once before wasnt as strong as everyone made it out to be... :/
Old Apr 24, 2010 | 08:16 AM
I doubt jb weld would do much of anything even in the short term, especially with the heat involved.
Old Apr 24, 2010 | 09:38 AM
CivicSpoon's Avatar
If I'm not mistaken, JB Weld isn't meant to deal with nearly that much heat, so it'd probably melt off or even catch fire.
Old Apr 24, 2010 | 10:20 AM
98civdx's Avatar
Master Detailer
Call honda it was a recall, they may still cover it, my friend got one, when his broke at around 170k, it may vary by dealer though.
Old Apr 24, 2010 | 10:22 AM
raidacaipo's Avatar
interesting.. when I had my d16y7 I also noticed that I had a crack on the header.. this should have been a recall but us Hondaphiles just swap the motor and header anyways
Old May 31, 2011 | 09:12 PM
STREETFIGHTER50's Avatar
Are you sure his car had 170k? I thought the limit for Honda/replacement was 150k??
Old May 31, 2011 | 10:34 PM
98civdx's Avatar
Master Detailer
I 'think' I'd have to call him and find out for sure. But that is likely why I put around. I don't know for sure.
Hell, I don't even know if he still has the car lol
But why did you bump over a year old thread?
Old May 31, 2011 | 10:53 PM
Well mine just came up cracked recently & I was searching for related threads. Jeez this happens quite a lot I see! Just sucks big time for us Cali folks! I wish I could just do the EX swap stuff
Old May 31, 2011 | 11:05 PM
98civdx's Avatar
Master Detailer
yea, it is a pretty well known issue for these cars. Fortunately mine hasn't cracked yet
Why can't you swap to the Y8 stuff?
I would still talk to the dealer, and just see what they can do for you.
Old Jun 1, 2011 | 12:17 AM
Can't do the Y8 stuff coz the Stupid California smog bullshit! Sometimes i wish i could just move to another state! Too much bullshit in Cali! As long as it burns clean thru the tail pipe is all what should matter... I'll try to talk to some dealers
Old Jun 1, 2011 | 01:46 AM
Texas4door's Avatar
So, you can't do the EX header swap and add the new catalytic converter and midpipe?
I did the same to mine years ago and it still passes inspection with flying colors
Old Jun 1, 2011 | 11:38 AM
98civdx's Avatar
Master Detailer
I always thought you could do it. Of course you'd have to swap everything over to a EX.
If aftermarket headers can pass why can't a OEM for a different car?
Old Jun 1, 2011 | 12:28 PM
StreetsideStig's Avatar
Hmm...I hadn't thought about it, but this might be what's going on with my '90 Accord. The manifold has a small crack, and that cylinder's exhaust valves are screwing up.
AFAccord
Apr 28, 2017 11:09 AM
jorge89
Jul 27, 2013 06:44 PM
civicdxguy
15
Feb 25, 2007 05:24 PM
RACEPAK
Nov 25, 2005 01:11 PM
Civic TSI
Jun 22, 2001 10:24 AM
