Changing water pump/timing belt
Old Mar 22, 2010 | 08:24 AM
JasonYo's Avatar
Default Changing water pump/timing belt
Hey, I needed to change my water pump on my b16a so I ordered the timing belt and water pump together, and it also came with a tensioner, cam seals, and crank seal.
I called this garage to see how much they would charge for the job and they said I needed a oil pan O ring or something?
This doesn't sound like a big deal but I never heard of it before, do they mean the crank seal maybe?
I just need the water pump changed really, everything else seems fine. They also said it's like 5 hours. This sounds long for a garage.
Old Mar 22, 2010 | 08:41 AM
dpetro1's Avatar
Default Re: Changing water pump/timing belt
they most likely are refering to the crank seal. its not required but smart to change while you are in there. also you may want to grab a valve cover gasket, gromets, and spark plug tube seals as well as a lower timing cover gasket.
5 hours seems pretty fair, its a long job. why not DIY and save $500 there are a ton of write-ups
https://honda-tech.com/zerothread?id=649277
Old Mar 22, 2010 | 08:52 AM
JasonYo's Avatar
Ok well I have the crank seal. I was going to get a valve cover gasket too but I was told I can reuse it, it's new anyways. I was just going to change it another time.
I Would like to do it myself but I'm not so sure I would be able to. I have done minor things on my car but nothing like this. Not to mention I can't spend a whole day or something fixing my car, I work 6 days a week and have to get alot of things done on my only day off =/. But there is a guy who is willing to do it for $150. He works at a performance shop but does jobs on his own to, I'm gonna give him a call.
Falloutkid90
Honda Civic (2001 - 2005)
Mar 19, 2024 07:30 AM
TougeCoupe
Nov 19, 2009 03:56 AM
dELfONiK
Feb 21, 2006 06:37 AM
idriveadelsol7
Dec 8, 2005 06:00 AM
pnthr30
Oct 31, 2003 07:29 AM
