struts and springs questions
Old Mar 22, 2010 | 08:17 AM
naterocks21's Avatar
Default struts and springs questions
hey. i bought a 91 crx and it has some bad coilovers on it. and i want to replace them with either new struts and shocks all around, or new coilovers. i want them to lower my car a little, and handle well. but i dont have alot to spend. so i want 2 know what u guys would recomend to get that performs well and isnt too expensive. thanks
Old Mar 22, 2010 | 08:22 AM
JacksonD's Avatar
Default Re: struts and springs questions
I am personally thinking about going tannabe orange grips with kyb adjustable struts, that rings in at around 600 and is like adjustable coils except you cant adjust drop.
Old Mar 22, 2010 | 08:23 AM
zsoccerdude17's Avatar
What your price range?
Old Mar 22, 2010 | 08:24 AM
JacksonD's Avatar
and what do you want to achieve? drop or stiffness or both?
Old Mar 23, 2010 | 07:49 AM
i want it to drop about an inch to an inch and a half. im looking to spend about 200 to 400 on them
Old Mar 23, 2010 | 09:56 AM
JacksonD's Avatar
for just the springs, or both?
Old Mar 23, 2010 | 10:12 AM
BrayzieEF9's Avatar
400 will get you a decent set of shocks and lowering springs.save up to 600 and you can get a good set of coilovers
Old Mar 23, 2010 | 02:23 PM
skipbudlong's Avatar
Really should save up. Unless you really cant take it anymore, like myself, and buy some monroes. They're alot better than my blown shocks, thats for sure.
Old Mar 23, 2010 | 02:59 PM
alx_90ef's Avatar
how do you know your coil overs are bad?
you might just have to replace your struts.
Old Mar 25, 2010 | 07:48 AM
the guy i bought if from said what he put on was the wrong size or something. so i just want 2 put different ones on. ill probably save up for sum coilovers. but what are some good brands and kinds of coilovers, and struts and springs?
Old Mar 25, 2010 | 08:18 AM
91CR-XSiR's Avatar
i got my 91 rex dropped on some simple kyb gr-2's with the tein springs. ive had them on for a while now and they feels very well when cornering... and the drop is just perfect!
Old Mar 25, 2010 | 09:01 AM
redef154's Avatar
TRIAL USER
tein springs with tokico illuminas are great to
Old Mar 25, 2010 | 09:25 AM
4gen5thtime's Avatar
for a cheap set up tokico blues or kyb's maybe skunk2 struts, and then for coils go with b&g, tein, skunk2, ebiak. Set up should run you around $350-400. Install them your self its not hard, just gotta be careful with the spring compression tool, not a job to do while drinkin the brewski.
Or you can save up to around 700 and get nice set up, koni's and ground controls, or a full skunk2 coilover set up list goes on and on.
Old Mar 26, 2010 | 09:02 PM
gforce_eg6's Avatar
well unless he has the original top hats, the new struts and springs won't do him any good if he can't MOUNT them...
my rex came with a mismatch set of rear springs/shocks from a EF sedan and fronts are blown no names with unknown stock springs..looks like a nhra drag car.
what I did is buy new OEM top hats and all the parts with it (bumpstops, nuts, spacers etc..) EXCEPT the springs and shocks and got a Tokico blues springs/shock combo from ebay. that way I know that my susp is all new and won't have ANY issues with it for awhile.
like the OP, just wanted a small drop for the occasional sprited runs.
ADJinfamy
Suspension & Brakes
Jun 2, 2014 09:18 AM
mikeunreal
Suspension & Brakes
Nov 1, 2005 06:34 AM
hondactr
Dec 4, 2004 04:56 PM
VTECRaZeR
Jan 10, 2004 03:47 PM
PnX-R
Apr 21, 2002 10:18 PM
