which cylinder to put da 2 02 sensor???
Old Sep 9, 2002 | 12:42 AM
EG3-R's Avatar
Default which cylinder to put da 2 02 sensor???
im gettin my headers put in this weekend and weld in 2 bungs.....juss wanna make sure wer to weld da bungs???.....1st, 2nd?????
thanks guys!!!
Old Sep 9, 2002 | 03:49 AM
slowman's Avatar
I took way too long
Default Re: which cylinder to put da 2 02 sensor??? (TYPE-ONE)
you should mount one wherever the header collects so the o2 sensor is sensing ALL cylinders not just one or two.
Old Sep 9, 2002 | 05:39 AM
SuperCivic's Avatar
on my stock jdm b16 manifold there is one bung in the number 2 flange and one in the number 3 flange, right where it goes from 4-2 about 5 inches from the exhaust ports on the head.
Old Sep 9, 2002 | 09:20 AM
Sgt_Ox's Avatar
Default Re: which cylinder to put da 2 02 sensor??? (SuperCivic)
Correct, now if you pay close attention each O2 sensor senses for a pair of cylinders only. Installing one near the collector will only cause you fuel problems which can lead to hesistation during acceleration. Your primary O2 sensor on your stock manifold is nearest the driver-side (which monitors cylinder 1 & 4), and your secondary, which is closer to the passenger-side monitors cylinders 2 & 3. Plug the O2 bung near the collector and weld a bung on one of each pairs of cylinders. I suggest cylinder 4 and 2 (if I'm not mistaken they look to be the easiest with enough clearance). NEVER, and I say again NEVER combine both O2 sensor to one (unless you get your ECU chipped to run only 1 O2 sensor), other wise you'll run in fuel problems like I said earlier, and experience hesitation in the mid-RPM band range.
Old Sep 9, 2002 | 09:23 AM
EF8_SiR's Avatar
Default Re: which cylinder to put da 2 02 sensor??? (MrDoHc2)
How do we get our ecu chipped to run only one o2?
Old Sep 9, 2002 | 09:24 AM
Sgt_Ox's Avatar
Default Re: which cylinder to put da 2 02 sensor??? (EF8_SiR)
http://www.jdmhondaparts.com/
check this site our KATMAN can chip your ECU
mrwokn
Mar 20, 2011 08:44 AM
stripes777
Jun 27, 2003 07:46 AM
madman604
May 12, 2003 08:44 AM
yorace2win
Oct 20, 2002 11:35 AM
