s2000 Antenna?? Need Advice
My integra antenna stopped working. I know this is a common problem. I was thinking about just replacing it with an s2000 antenna. I was wondering if anyone has done it. If it was easy and how it looked..
Will this antenna fit??
If so, is the install easy or what..
http://cgi.ebay.com/ebaymotors/OEM-H...item588655c819
Thank you-
Thank you-
Here... http://www.team-integra.net/sections...?ArticleID=859
If you click "Search this Forum" and search for S2000 antenna, you'll find a wealth of articles...this one being the best i saw
they also sell the rubber ones at kragan for about 20 bucks or less works really great about 8inches long just remove the old assembly take off the nut and it mounts rite on just connect the wire and your go to go
the S2K antenna will go on most cars wit a lil bit of work. it would fit on my 02 WS6 even, if i weren't selling it (or if it don't sell fast) i'll be adding the S2K atenna to the car. looks good and is much better than an electric motor antenna
Lo customs sells an antenna very similar to the s2k one that most integra owners upgrade to
http://www.locustom.com/shark2_kit.htm
The base on the Shark one looks like ***. S2K mast w/ OEM Integra antenna base looks best IMHO.
<-- been rocking the S2K mast since 2002.
