Power locks, windows, mirrors conversion 94 accord
Hey Guys,
I have a 94 dx accord which as you know is manual everything. I have a 96 accord ex parts car which has power everything even the driver seat. What I am currently doing is removing everything from the parts car. I took the dash, carpet door panels, and harnesses out of the doors. My question is can I use anything from this to do my conversion? So far I see that the door harness in the dx does not contain any of the connections I need. Looks like I need to pull the whole freakin harness out of the parts car ran behind the dash. Is there anyway to do this easier. This is a 4 door accord also. I see I need the floor harness also? Is obd2 going to be a problem?
Thanks
Thanks
There's not really an easy way to do it - you'll have to swap out all the harnesses - but your other issue is the 96 is OBDII and the 94 is OBDI you'll have more headaches than it's worth. I'm unsure what wiring changes there were between these years in the ECU area and especially with the OBDII connector.
Minimum you'll need to redo all the interior harnesses.
VTEC IS UR BEST FRIEND
Mar 8, 2010 06:56 AM
