D15B Hesitates when revving
Old Mar 21, 2010 | 10:20 PM
nickxlucas's Avatar
TRIAL USER
Icon3 D15B Hesitates when revving
Hi everyone, i have just installed a JDM D15B into my 98 DX. I bought the OBDII to OBDI conversion harness and ECU. I fired the car up for the first time today and it has a rough idle and when you give it throttle it hesitates and wont rev smoothly. Theres a couple things im unsure about. I used my original Y7 injectors and O2 sensor. Theres also a white 2 wire sensor on the back of the intake at the bottom that im unsure as to what its for. any help would be greatly appreciated. thanks
Old Feb 3, 2011 | 07:24 PM
zGo's Avatar
zGo
Default Re: D15B Hesitates when revving
Bump, I have the same issue but not sure what's causing it.
Old Feb 4, 2011 | 08:32 AM
thecruzs2007@yahoo.com's Avatar
you have obd2 injectors on an obd1 harness?? try getting z6 or b7 injectors and see if that helps any
Old Feb 4, 2011 | 08:40 AM
slogfilet's Avatar
Which D15B is it? There were three "flavors," I believe.
Old Feb 4, 2011 | 08:51 AM
DSMAddicted's Avatar
This guy is very knowledgeable regarding this swap (assuming it's "the" D15B - 3-stage VTEC). If the link doesn't help, try contacting him.
Good luck,
-Walter
Old Feb 4, 2011 | 09:08 AM
djslim23's Avatar
Sounds like the injectors. y7 injectors are smaller than vtec injectors..
DiabolicDiablo
18
May 27, 2012 02:45 PM
big-cat
Nov 3, 2006 07:17 PM
aemciv
Mar 29, 2003 11:58 AM
markedOO1
Nov 26, 2001 07:50 AM
