Fuel Pump Fuse
I'm replacing my fuel filter for the first time. I know you have to take out the fuel pump relay before I take out the filter or else the fuel will shoot out everywhere. I looked under my dash at the fuse box, but it's missing the cover so I don't know which fuse to take out. Can someone point me in the right direction? Thanks
Just turn the car off and replace the filter, no need to disable fuel system like your fuel filter instructions say.
When you crack the line open, it'll spray a little fuel, just let it spray until it stops, then continue uncscrewing the line. It won't spray longer than 2 seconds and the amount of fuel you'll lose will be probably less than a penny's worth.
CPT Del sol
15
Oct 5, 2011 06:15 PM
