View Poll Results: Which cams would be better?
skunk2 tuner 3
34.29%
skunk2 pro 1
57.14%
98 Type R
8.57%
Voters: 35. You may not vote on this poll
s2s3 tuner vs pro1 vs 98 type r cams
Old Mar 21, 2010 | 06:41 PM
sprjit22's Avatar
Icon2 s2s3 tuner vs pro1 vs 98 type r cams
Im looking for feed back on you guys that have used both sskunk2 tuner 3 cams and pro1's. The reason for my interest is I have some one that has a set of s2 tuner 3 cams that wants to trade me my 98 type r cams and 40 on my end. Here is what my build consist of.
b18c5 block
GE Sleeves
13.0-1cr Cp pistons
ls crank
eagle rods
b16 head, P&P
Springs & retainers (they will be changed when I install cams anyways)
98 type r cams
2 stage nitrous (50 single fogger 150 direct port)
2 fuel systems
OEM Fuel system runs motor (93)
Secondary fuel system runs the nitrous set up. (c16)
Yes it is tuned.
My question is how much better are the sk pro 1's vs tuner 3 and 98 type r?
Old Mar 22, 2010 | 12:09 AM
C_Rock77's Avatar
Default Re: s2s3 tuner vs pro1 vs 98 type r cams
Just a heads up....don't just look at the NUMBER of votes....look at WHO the votes come from.
Sounds like that would be one FUN-*** car!
I do kinda wonder why you chose to run 13:1 on 93 octane, though. Are you just doing that to drive it? or are you wanting something that will PERFORM with 93?
Old Mar 22, 2010 | 08:31 AM
sprjit22's Avatar
It is a daily driver and I cant afford race gas 24/7 thats why i just spray race gas. Im thinking of getting the stage 3 since I can get them for so cheap.
Old Mar 22, 2010 | 08:50 AM
ilikehonda's Avatar
you have more than enough compression to run the pro 1...you may even look into the pro2
Old Mar 22, 2010 | 09:03 AM
88Hatchy's Avatar
My vote goes to the Pro1 cams. Who is doing to tuning?
Old Mar 22, 2010 | 09:47 AM
icemangsr2's Avatar
you're compression is high enough to run pro2s for sure.
Old Mar 22, 2010 | 10:21 AM
killerpenguin21's Avatar
of course the fact is cam choice isnt decided by compression it is decided by flow.
pick one of the two best cams out right now the pro1 or pro2, whichever will give you proper clearance.
Old Mar 22, 2010 | 05:37 PM
sprjit22's Avatar
Alpha will be tuning the car.
Yeah Im sure Id love the pro2 for sure but, Im leaning towards the tuner 3 for now since it will be 40 and my old type r cams.
Old Mar 22, 2010 | 09:14 PM
88Hatchy's Avatar
You might have to pull a lot of timing to run the S2S3 cams, especially with such high compression.
Old Mar 23, 2010 | 03:33 AM
Teamdiesel's Avatar
Why? I ran those cams on my 13.5:1 compression without any problems. I voted these cams because they WILL make more torque and hp than the Pro1's hands down. If you only want more power from 3000-5500 rpms then by all means use the Pro1's .
Old Mar 23, 2010 | 11:44 AM
Dat1BVtecN's Avatar
I ran Pro 1's in my 11:5 ls/vtec build and they ran great! With your setup, Pro1's would be nice...BUT I might go with Pro 2's.
Old Mar 23, 2010 | 12:08 PM
88Hatchy's Avatar
I've never heard this before. Do you have a graph?
Old Mar 23, 2010 | 04:19 PM
Teamdiesel's Avatar
The Pro1's are smaller than the S2S3 cams on the vtec lobes so you would only get better power out of that setup above below vtec.
Old Mar 23, 2010 | 06:51 PM
88Hatchy's Avatar
EDIT: I had it backwards.
EDIT(again): The S2S3 cams have more total duration, but the Pro1 has a faster ramp speed. So the valves open and close faster with the Pro1 cams. Shouldn't this mean that they're effectively open longer?
b20vtek's Avatar
I made 230whp with my tunner 3's in my opinion i think they are a great set of cams.
Old Mar 23, 2010 | 07:03 PM
88Hatchy's Avatar
I'm not saying either set is bad. I'm just trying to learn more about what makes each cam good.
Old Mar 23, 2010 | 09:09 PM
4g hatch's Avatar
from what ive seen on here i would pick the st3's hands down, now pro2's or pro3's if you got a 2.0 liter is a different story. the tuner cams are old but still put out dam good results
Old Mar 24, 2010 | 03:42 AM
Teamdiesel's Avatar
Hp and TQ in the upper band of the rpm with the Pro1's is weak. They have amazing midrange but their topend power, according to most of the graphs I have see, is just damn weak.
Old Mar 24, 2010 | 08:30 AM
ilikehonda's Avatar
compared to what? i extended my stock power band by almost 1k rpm
Old Jun 30, 2010 | 04:47 AM
Natural Aspirations's Avatar
From the choices you have given.
Drag car Tuner STAGE 3
Street Car Pro 1
The mid-range improvements from the pro series cams are drastic on most engines
Old Jun 30, 2010 | 08:38 AM
Garrett's Avatar
pro2/3 or s3
S3 will make more top end, but I'm curious to see what pro3 could do
I allready made a test to compare Pro1 VS pro2 last year, and I have good reason to think that I will compare pro2 VS pro3 in a build engine in a few weeks
Old Mar 20, 2011 | 03:25 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
9 months old lol
Old Mar 22, 2011 | 11:38 PM
b16sir2000's Avatar
whats done to your B20 and what kinda dyno did u go on i made 208hp 151tq on tuner 3's on a dynapak2000 with mine..lmk
MugenLudenB00st
May 28, 2005 09:41 AM
Linh.
Mar 24, 2004 11:24 PM
shant
Feb 23, 2004 10:30 AM
EGkTiOn_CiViC
Aug 19, 2002 05:32 PM
EGkTiOn_CiViC
Aug 19, 2002 03:02 PM
