carbon fiber help
Old Mar 21, 2010 | 06:25 PM
berger1302's Avatar
Default carbon fiber help
i have a carbon fiber hood on my 98 GSR and it's fading really bad. does anybody know if it can just be recleared or what do i need to do?
Old Mar 21, 2010 | 07:31 PM
Blue Horiz0n's Avatar
Default Re: carbon fiber help
You can try reclearing it but the uv could have got the best of it
Old Mar 23, 2010 | 03:56 PM
berger1302's Avatar
ok. i put 2 coats of wax on it the other day and it looks a lot better but you can still see some fade in it. water doesnt even bead up on it anymore so its acting like the clear is gone off it. does anyone know what grit sand paper to wet sand with?
Old Mar 23, 2010 | 04:01 PM
SiZ's Avatar
SiZ
If you're going to re clear it you can sand it with 320-400. But yes, most likely the UV rays have damaged the carbon already.
Old Mar 28, 2010 | 10:41 AM
boxeocampeon's Avatar
try getting clear coat redone on it and also you should have bought the uv spray protector
Old Mar 31, 2010 | 06:10 PM
Fibercation's Avatar
no damage to the carbon....that is not what fades...its the resin...if you sand it down enough and not burn through the weave and then reclear it will look new.
Old Mar 31, 2010 | 07:36 PM
Eyger's Avatar
^SiZ, Those grits are too low. You would cause more work for yourself trying to get the scratches out.
You should be using a Dual Action sander with 400, or wetsand by hand with 600 and then clear it up.
Old Apr 1, 2010 | 01:21 PM
SiZ's Avatar
SiZ
I'm just speaking from experience, its what I used about 3 months ago when I did mine. Actually, I started blocking it with 180, then 220, 320, and 400. Then clear. But whatever you want.
I work with CF everyday, and most certainly you can clear over 400 scratches.
Old Apr 5, 2010 | 09:10 AM
darqhaven's Avatar
good thread!!
darqhaven's Avatar
somebody add some pic
Old Apr 5, 2010 | 11:45 PM
SiZ's Avatar
SiZ
This is the only pic I have of mine really. Its bad, you can't see the weave directly, and the hood is dirty, but you can see how flat it is now after I sanded it compared to a normal cheap pre-preg hood.
Old Apr 7, 2010 | 11:50 AM
berger1302's Avatar
ill get some pics up of mine when i reclear it. im more worried about getting it running again then how the hood looks lol
meheartmycivic
Aug 18, 2010 03:34 PM
EHondaJDM
Paint and Body
22
May 3, 2010 04:34 PM
san_diego_DC
Paint and Body
Mar 8, 2009 06:53 PM
EG-boy
Paint and Body
14
Mar 3, 2009 08:48 PM
SPOOLINmatt
Feb 15, 2005 09:02 PM
