Tw:Boosted 94 teg
*delete*
white 94 acura integra
semi built b18b1
bored 81.5mm
srp 8:1 comp pistons
egale H beam rods
egale head studs
rhino pac ceramic 5 puck clutch
450cc injectors
mini ram turbo manifold
ebay 57 trim turbo with not shaft play
3inch charge piping
greddy bov
knockoff tail wastgate
boost controler
lowering springs
skunk pro 2 lca's
3in stright pipe exhaust
this is a clean car the motor has little over 6k on it the trany doesnt grind its on a basemap for 10psi i was going to get it tuned for 20 psi on E85 turbo spools up nice im sure im forgeting some stuff but call or txt me anytime at 608-438-6154
semi built b18b1
bored 81.5mm
egale H beam rods
egale head studs
450cc injectors
3inch charge piping
greddy bov
boost controler
lowering springs
skunk pro 2 lca's
